Function of AC Power Transducer: Does It Output 4-20mA Like a Power Analyzer?
300 7
  • #1 21669252
    Rem Henson
  • #2 21669253
    Frank Bushnell
  • Clarifying transducer type and measurement method
    #3 21669254
    Kevin Parmenter
  • #4 21669255
    Rem Henson
  • Summary of analog outputs and PC link capabilities
    #5 21669256
    Frank Bushnell
  • Modbus-based transducer as programmable test meter
    #6 21669257
    Mark Harrington
  • Potentiometer wiper arcing can ignite combustible vapors
    #7 21669258
    Dan Xiao
  • Industrial transducer outputs via RS232 or RS485
    #8 21669259
    Mark Harrington
An AC power transducer functions by converting electrical parameters such as voltage and current into proportional analog or digital signals for monitoring and measurement purposes. Unlike a power analyzer, which provides detailed power quality analysis and recording capabilities, a power transducer typically outputs standardized signals like 4-20mA or digital communication protocols (e.g., Modbus via RS232/RS485/USB) to represent power parameters including power usage, power factor, and phase difference. These devices often require external voltage and current transformers to extend measurement ranges and can be programmed via computer interfaces for alarm settings and data acquisition. The transducer acts as an intermediary measurement device, sometimes described as a sophisticated test meter, enabling integration with data acquisition systems for further analysis. Its suitability depends on the application scale, such as moderate-sized power plants or industrial environments. Various types of transducers exist, including Hall effect sensors, current probes, shunts, and transformers, each with specific operational principles. The device discussed supports analog outputs and digital communication but may need additional software for data recording and analysis.
