Simple Schematic for 100W 3A 36V LED Driver Powered by 220V AC 50Hz DIY Project
366 19
How can I build a simple 220V AC to 36V, 3A constant-current driver for a 100W LED array?
You need a constant-current power supply, not just a simple 36V fixed-voltage supply; for this LED array the driver should deliver about 3A at up to at least 36V, ideally from a switch-mode design, and an off-the-shelf LED driver is the most practical solution because a 220VAC-to-36V/3A constant-current supply is not trivial to design [#21665912] [#21665918] If you are unsure about the exact behavior of the module, start testing it with a bench supply that has an adjustable current limit, set it to around 35V and 100mA, then slowly raise the current while watching temperature; if the temperature rises above about 100°C before reaching full current, the heatsink is inadequate [#21665912] The datasheet information posted later indicates the array needs proper heat dissipation, with a maximum operating temperature of 60°C and only about 5 seconds of operation without appropriate cooling, so a substantial heatsink and possibly a fan are needed [#21665918] A fixed 36V power supply alone will not let you control LED current or brightness properly [#21665914]
  • #1 21665899
    warick minkley
  • #2 21665900
    Earl Albin
  • #3 21665901
    Frank Bushnell
  • #4 21665902
    warick minkley
  • #5 21665903
    warick minkley
  • #6 21665904
    Earl Albin
  • #7 21665905
    Earl Albin
  • #8 21665906
    Frank Bushnell
  • #9 21665907
    Mark Harrington
  • #10 21665908
    warick minkley
  • #11 21665909
    Mark Harrington
  • #12 21665910
    Mark Harrington
  • Request for schematic and datasheet before help
    #13 21665911
    Mark Harrington
  • Recommend constant-current switchmode driver and bench test setup
    #14 21665912
    Steve Lawson
  • #15 21665913
    warick minkley
  • Need constant-current or PWM dimming control
    #16 21665914
    Earl Albin
  • Need for full schematics and parts support
    #17 21665915
    Mark Harrington
  • #18 21665916
    Steve Lawson
  • #19 21665917
    Julius Adesemoye
  • Constant-current driver and heatsink required
    #20 21665918
    Steve Lawson
The discussion centers on designing a simple LED driver circuit to power a 100W, 36V, 3A LED chip array (10x10 surface mount) from a 220V AC 50Hz source for a DIY project. The LED module specified is from Zhejiang Linova Technology, model RG-DGL-100C-CW(WW). Key points emphasize the necessity of a constant current (CC) driver rather than a constant voltage (CV) supply to maintain stable current as the LED heats up, preventing damage and ensuring proper operation. A switch-mode power supply (SMPS) with constant current regulation is recommended for efficiency and reliability. The importance of adequate heat dissipation, including proper heatsinking and possibly active cooling, is stressed due to the high power and thermal output of the LED array. Without a datasheet or schematic, designing a suitable driver is challenging; users are advised to obtain detailed specifications and consider off-the-shelf constant current LED drivers. PWM dimming or current modulation methods are suggested for brightness control. The complexity of designing a 220V to 36V, 3A switch-mode constant current supply is acknowledged, with recommendations to use adjustable bench power supplies for testing and prototyping. Overall, the project requires careful attention to current regulation, thermal management, and appropriate power conversion techniques.
TL;DR: Use a switch‑mode constant‑current LED driver: 100 W array needs up to 3.2 A at ~36 V; "what you need is a constant current power supply." [Elektroda, Steve Lawson, post #21665918]
Why it matters: This FAQ helps DIYers safely power and dim a 100 W, 36 V/3 A LED from 220 VAC without cooking the LED.
What driver do I need to run a 100 W, 36 V/3 A LED from 220 VAC?
Use a switch‑mode constant‑current power supply (CCPS) rated to at least 3.0 A and up to 36 V. The LED’s maximum continuous forward current is 3.2 A at 25 °C, so select a driver with headroom. Steve’s guidance: “what you need is a constant current power supply.” This approach keeps current stable as the LED warms up. It also positions you for proper thermal management later. [Elektroda, Steve Lawson, post #21665918]
Is a 36 V, 3 A constant‑voltage adapter enough?
No. A constant‑voltage supply will not regulate LED current as temperature changes. You risk runaway current and shortened life. For brightness control or safe operation, you need constant‑current regulation or PWM. Use the CV unit only as a bulk source feeding a proper LED driver stage. [Elektroda, Earl Albin, post #21665914]
How can I dim a 100 W LED safely?
Dim by controlling current. Two common ways: a constant‑current driver with an analog/digital dim input, or a PWM stage that modulates current. A plain 36 V CV brick cannot dim by itself. Pair it with a CC driver or PWM module rated for 3 A. [Elektroda, Earl Albin, post #21665914]
What heatsink size do I need?
The datasheet guidance cited in‑thread suggests 0.008 m²/W for aluminum. At 100 W that implies about 0.8 m² surface area, which is large. Use a substantial finned heatsink and consider a fan to shrink size. Validate by staged power‑on tests and temperature checks. [Elektroda, Steve Lawson, post #21665918]
Can I power the LED without a heatsink to test it?
Limit on‑time to 5 seconds at room temperature if no heatsink is attached. Exceeding this risks permanent damage. Better: mount to a heatsink with thermal paste before any serious testing. Add a fan for more thermal margin. [Elektroda, Steve Lawson, post #21665918]
What’s a constant‑current power supply (CCPS) in this context?
A CCPS maintains a set output current (e.g., 3 A) while allowing voltage to vary up to the LED’s forward voltage (~36 V). This protects against current drift with temperature and is the recommended topology for high‑power LEDs. [Elektroda, Steve Lawson, post #21665918]
How should I bench‑test this LED the first time? (3‑step how‑to)
  1. Mount the LED to a heatsink with thermal paste; attach a temperature probe.
  2. Use a bench supply with current limit; set ~35 V, 100 mA limit.
  3. Slowly increase current while monitoring temperature; stop if case nears 60 °C. [Elektroda, Steve Lawson, post #21665912]
What temperatures are safe, and how do I measure them?
Keep operating temperature below 60 °C at the module. Junction temperature rises faster than the case, so measure frequently and allow stabilization between steps. Non‑contact IR meters respond quickly; thermistors respond slower. This lag can hide dangerous overshoot. [Elektroda, Steve Lawson, post #21665918]
Why do forum members insist on the exact part number or datasheet?
LED arrays vary in forward voltage, max current, and thermal limits. Designers need the part number and datasheet to size drivers and heatsinks correctly. Without it, guidance can be unsafe or wasteful. [Elektroda, Earl Albin, post #21665905]
Can I just buy a ready‑made driver instead of designing one?
Yes. Off‑the‑shelf 220 VAC→CC LED drivers for ~36 V/3 A exist and are inexpensive. This avoids high‑voltage design complexity and improves safety. Pick reputable units with dimming inputs if needed. [Elektroda, Steve Lawson, post #21665918]
What’s PWM dimming, in simple terms?
Pulse‑width modulation switches the LED current on and off rapidly. Changing the on‑time fraction changes perceived brightness while keeping peak current controlled. Pair PWM with a CC driver for reliable results at 3 A. [Elektroda, Steve Lawson, post #21665916]
What happens if my heatsink is undersized? (edge case)
The case temperature will rise quickly, while the junction can overshoot before your sensor catches up. This unseen spike can exceed limits and degrade the LED. If you hit 60 °C before full current, upgrade the heatsink or add a fan. [Elektroda, Steve Lawson, post #21665918]
Is a transformer‑rectifier‑capacitor‑regulator stack overkill here?
For 100 W at 3 A, a linear regulator wastes substantial power as heat. A switch‑mode CC driver is far more efficient and compact. Use linear stages only for low‑power or lab setups. [Elektroda, Steve Lawson, post #21665918]
Any practical tips before first full‑power run?
Pre‑mount the LED, confirm thermal paste coverage, and ensure good airflow. Start below 3 A, observe temperature, and step up gradually. Stop if temperature trend accelerates. “The cooler the better” for longevity. [Elektroda, Steve Lawson, post #21665912]
