Efficient Current Limiting Circuit for CREE Q5 LED With Minimal Heat Dissipation
348 6
  • Use a constant-current LED driver with DMX dimming
    #1 21671615
    Erwin Redl
  • Switch-mode current regulator recommended for high-power LED
    #2 21671616
    Steve Lawson
  • DMX driver output can feed PWM input
    #4 21671618
    Steve Lawson
  • #5 21671619
    Steve Lawson
  • DMX current limiting drivers tested for LED dimming
    #6 21671620
    Erwin Redl
  • Heat sinking preferred over fan cooling for high-current LEDs
    #7 21671621
    Rolte Regmi
Controlling high-brightness CREE Q5 LEDs at 700-1000mA requires efficient current regulation to minimize heat dissipation. Using simple series resistors at 12VDC leads to high power dissipation and large heat sinks. Switch-mode current regulators are recommended for such high-power LEDs, as LEDs are current-driven devices and forward voltage alone is insufficient for regulation. PWM dimming, potentially provided by DMX controllers, can be used to control brightness if voltage levels are compatible. Several resources and example circuits for switch-mode LED drivers with PWM inputs were suggested, including technical application notes and LED driver dimmer PCBs. Commercial DMX-controlled current limiting drivers from EUChips (models PX704 and PX705) offer configurable current settings (300-700mA) and multi-channel operation, providing practical solutions for LED dimming with reduced heat dissipation. Heat sinks remain important for thermal management, while fans are generally not recommended due to power consumption concerns.
