How to Control PC Parallel Port for Infrared Electronic Lock Project?
600 39
How can I control a PC parallel port from a desktop application for an infrared electronic lock project?
Use USB or serial hardware instead of trying to drive the parallel port directly, because modern Windows makes LPT access difficult and often requires special drivers or tools [#21665942][#21665948][#21665956] For the simplest path, build a small controller around a PIC or similar MCU, add an FTDI USB-to-serial/USB-to-TTL interface or a MAX232 RS232 level converter, and have your PC GUI send lock/unlock commands to that hardware [#21665948][#21665956] If you still want true LPT access under Windows NT/XP, you need a direct-port toolkit/driver and may also have to disable LPT polling in the registry with `HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Parport\Parameters` -> `DisableWarmPoll=1` [#21665961][#21665964] There is also a USB-to-LPT bridge project based on an AVR MCU if you want to keep the parallel-port style interface while moving the actual connection to USB [#21665966] For the software side, people suggested Java, C#, VB, Delphi, or Tcl/Tk for a simple GUI with lock/unlock buttons [#21665948][#21665958][#21665956]
  • Use a parallel-port driver to control an IR transmitter
    #1 21665938
    George James
  • #2 21665939
    Eugene Lisovy
  • #3 21665940
    Eugene Lisovy
  • #4 21665941
    Steve Lawson
  • Serial port interface recommended over parallel port
    #5 21665942
    Mark Harrington
  • Parallel port access via zip-packaged DLL and installer
    #6 21665943
    Mark Harrington
  • #7 21665944
    Mark Harrington
  • #8 21665945
    George James
  • #9 21665946
    Mark Harrington
  • #10 21665947
    George James
  • USB-to-TTL and USB-to-serial adapter recommendations
    #11 21665948
    Steve Lawson
  • #12 21665949
    George James
  • Java parallel port driver suggestion for native access
    #13 21665950
    Mark Harrington
  • Suggesting USB control instead of parallel port
    #14 21665951
    Steve Lawson
  • Encouragement to use SparkFun support resources
    #15 21665952
    Steve Lawson
  • Suggests using serial or USB with FTDI and a GUI spec
    #16 21665953
    Mark Harrington
  • #17 21665954
    George James
  • #18 21665955
    Mark Harrington
  • Use a PIC with FTDI or MAX232 for PC control
    #19 21665956
    Mark Harrington
  • #20 21665957
    Aniruddh Mali
  • #21 21665958
    Steve Lawson
  • #22 21665959
    Steve Lawson
  • #23 21665960
    Steve Lawson
  • #24 21665961
    Eugene Lisovy
  • #25 21665962
    Eugene Lisovy
  • #26 21665963
    Eugene Lisovy
  • #27 21665964
    Eugene Lisovy
  • #28 21665965
    Steve Lawson
  • #30 21665967
    Eugene Lisovy
The discussion addresses controlling PC parallel ports for an infrared electronic lock project. Key challenges include limited direct access to parallel ports on modern Windows OS (especially XP and later), requiring special drivers or registry modifications such as disabling LPT polling via the registry key "DisableWarmPoll". Many users report difficulties with parallel port interfacing due to OS restrictions and driver issues, leading to recommendations to use serial ports or USB interfaces instead. USB-to-serial or USB-to-TTL converters (e.g., FTDI chips, PL2303HX modules) are suggested as more reliable alternatives. Several tutorials and toolkits are referenced for parallel port interfacing, including resources at logix4u.net, beyondlogic.org, and eeweb.com. Programming options for GUI control include Visual Basic, Delphi, Tcl/Tk, Java (with native method calls), and C#. Some users recommend microcontroller-based solutions using PIC MCUs with RS232 level converters (MAX232C) or FTDI chips for USB communication. Registry editing advice includes backing up before changes and awareness of 32-bit vs 64-bit Windows differences. Additional ideas include integrating smart card readers, webcams, or Raspberry Pi for advanced control and networking. Overall, the consensus favors using serial or USB interfaces over direct parallel port control due to modern OS limitations and driver support challenges.
TL;DR: For desktop-controlled IR locks, skip legacy LPT and use USB‑to‑serial; Steve shared 5 example adapters and noted, “what you want is a USB to TTL.” [Elektroda, Steve Lawson, post #21665948]
Why it matters: This approach works on modern PCs, simplifies coding, and avoids brittle parallel‑port drivers—perfect for beginners building reliable locks.
How do I control a PC port for an infrared lock in 2025?
Use a USB‑to‑serial (USB‑to‑TTL/RS‑232) adapter and drive a microcontroller (e.g., PIC/AVR) that switches your IR transmitter/relay. This avoids fragile LPT access on modern OSes and gives you a stable virtual COM port for your app. Steve’s post lists multiple adapter options. [Elektroda, Steve Lawson, post #21665948]
Should I avoid the parallel (LPT) port for new builds?
Yes. LPT is phased out on new PCs and driver access is inconsistent on NT/XP and later. Engineers in the thread moved to serial or USB front ends because they "always work" across systems. That reliability matters for locks and safety. [Elektroda, Mark Harrington, post #21665942]
What exactly is a USB‑to‑TTL/USB‑to‑RS232 adapter?
It converts USB from your PC into a UART signal (TTL level or RS‑232 level) that microcontrollers understand. Common chipsets include FTDI; vendors like SparkFun, Adafruit, and Parallax sell ready modules. Your PC sees a COM port you can open from most languages. [Elektroda, Steve Lawson, post #21665948]
Quick 3‑step: how do I build a simple USB/serial front end for the lock?
  1. Hardware: Pair an FTDI module or a MAX232 RS‑232 level shifter with a small MCU to drive your relay/IR LED.
  2. Firmware: Parse simple bytes/ASCII over UART to toggle lock states.
  3. PC app: Send commands from Java or C# over the virtual COM port. [Elektroda, Mark Harrington, post #21665956]
How can I access the LPT port on Windows XP/NT if I insist on using it?
Use a port‑access toolkit/driver designed for NT‑like systems to gain user‑mode I/O to LPT registers. This enables experiments or legacy hardware under controlled conditions, though it’s more brittle than USB‑serial. [Elektroda, Eugene Lisovy, post #21665961]
Is editing the Windows registry safe for LPT tweaks?
Treat it as risky. Back up the registry first. If something breaks, boot Safe Mode and restore. A single typo can derail your system. As Steve cautioned, "better safe than sorry." [Elektroda, Steve Lawson, post #21665965]
How do I disable Windows XP’s LPT polling and why would I?
DisableWarmPoll=1 under the Parport\Parameters key stops periodic LPT polling that can interfere with direct port experiments. This is an advanced change; document and back up before editing. [Elektroda, Eugene Lisovy, post #21665964]
Can a beginner build the GUI to lock/unlock?
Yes. Options include Visual Basic, Delphi, or Tcl/Tk. Each can open the adapter’s COM port and bind buttons to send bytes. Tcl/Tk is cross‑platform and approachable; VB offers a very friendly designer for quick results. [Elektroda, Steve Lawson, post #21665958]
What languages and tools did the thread suggest for the PC side?
Java, C#, VB, Delphi, and Tcl/Tk were suggested. Mark noted JDK7 was then current and highlighted cross‑platform benefits. Choose what you know; serial libraries exist for all. [Elektroda, Mark Harrington, post #21665956]
What’s FTDI, MAX232, LPT, and TTL in simple terms?
FTDI: USB‑UART bridge chips/modules. MAX232: converts TTL UART to RS‑232 levels. LPT: legacy 25‑pin parallel printer port. TTL: 5V/3.3V logic UART signal for MCUs. These terms appear across the suggested hardware paths. [Elektroda, Steve Lawson, post #21665948]
Is there a low‑cost DIY bridge if I must keep LPT hardware?
Yes. An AVR‑based USB2LPT project emulates a printer port over USB, useful for legacy devices when native LPT is unavailable. It includes schematics and firmware. [Elektroda, Eugene Lisovy, post #21665966]
Any beginner‑friendly learning resources or communities?
SparkFun tutorials and support forums are solid starting points. Follow a guided USB‑to‑serial example, then adapt it to send your lock commands. Ask questions as you hit roadblocks. [Elektroda, Steve Lawson, post #21665952]
Can I configure or test ports with HyperTerminal?
You can test serial communications with HyperTerminal by opening the virtual COM port and sending bytes to your MCU. It does not configure LPT, but it’s handy for serial debugging. [Elektroda, Aniruddh Mali, post #21665957]
What pitfalls should I expect on Windows XP and drivers?
Expect driver hurdles, 32‑bit vs 64‑bit confusion, and tools that work only in DOS/Win9x. Many gave up on LPT under XP and pivoted to serial/USB. Plan for that fallback early. [Elektroda, Mark Harrington, post #21665972]
Where can I read a primer on parallel ports?
Start with the tutorial linked in the thread. It explains LPT basics, signals, and interfacing concepts useful for understanding legacy control paths. [Elektroda, Eugene Lisovy, post #21665939]
Is Tcl/Tk still free for hobby use?
Yes. ActiveTcl offers a free Community edition with forum support, suitable for learning and small tools that talk to COM ports. [Elektroda, Steve Lawson, post #21665960]
