How to Modify Hearing Aid Circuit for Clearer Sound? Role of C3, C4, C9, C10, R5, R6?
312 9
How can I modify this circuit to make the sound clearer, and what are C3, C4, C9, C10, R5, and R6 used for?
You should not treat this as a real hearing aid circuit, because the replies say it is not a hearing aid design and it draws too much current to run from normal hearing-aid batteries [#21666002] [#21666007] The circuit would need larger batteries in an external box if you wanted it to run for any useful time [#21666007] One component-value note given in the thread is that 8k2 means 8.2 kΩ, using the letter as the decimal point [#21666003]
  • Request for clearer sound modifications and component roles
    #1 21666000
    George James
  • #2 21666001
    George James
  • #3 21666002
    Steve Lawson
  • #4 21666003
    Steve Lawson
  • #5 21666004
    George James
  • #6 21666005
    George James
  • #7 21666006
    Steve Lawson
  • #8 21666007
    Steve Lawson
  • #9 21666008
    George James
  • #10 21666009
    George James
The discussion centers on modifying a hearing aid circuit to achieve clearer sound quality, with specific inquiries about the roles and value calculations of components C3, C4, C9, C10, R5, and R6. Clarifications were provided on resistor notation, explaining that values like "8k2" represent 8.2 kilo-ohms, where the letter replaces the decimal point for clarity and compactness. However, it was pointed out that the provided circuit is not a typical hearing aid design, as it consumes excessive current unsuitable for standard hearing aid batteries, implying it may be intended for external use with larger power sources. Additional practical concerns include substituting unavailable capacitors (e.g., 330 pF) and selecting appropriate voltage ratings for electrolytic capacitors, with suggestions to use common voltage ratings such as 16V or 36V. The discussion also touched on the calculation of base and emitter voltages in transistor stages, though no definitive formulae were provided. Overall, the thread highlights the importance of component selection, power consumption considerations, and notation understanding in audio amplification circuits related to hearing aids.
