ICs for Serial Data Transmission Over DC Power Lines—Powerline Communication Options
324 9
How can I send serial data over the same two wires used by a DC power supply, and is there an IC for it?
Yes, there are power-line communication ICs that can carry serial data over the same two wires as a DC supply; one specific suggestion is Yitran’s IT700, which is said to interface serially and communicate over the two DC wires [#21666384] Be aware that many power-line data systems are designed for AC mains and will not work unchanged on DC [#21666385] The thread also suggests coupling or isolating the signal with capacitors or a center-tapped transformer so the data rides on the line while the DC stays on the load, though supply smoothing capacitance may attenuate the signal [#21666382] [#21666383] [#21666385] Other PLC families mentioned as worth checking were TI, Atmel, and Echelon [#21666389]
  • #1 21666381
    Daniel Kuropatwa
  • Capacitive coupling may isolate data from supply
    #2 21666382
    Frank Bushnell
  • Center-tapped transformer enables isolated serial over power
    #3 21666383
    Earl Albin
  • #4 21666384
    Guy Ellenbogen
  • Custom transformer ratio for DC line modulation
    #5 21666385
    Earl Albin
  • #6 21666386
    Earl Albin
  • X10 protocol resources for powerline communication
    #7 21666387
    Mark Harrington
  • #8 21666388
    Mark Harrington
  • HomePlug Green Powerline communication references
    #10 21666390
    Mark Harrington
Transmitting serial data over existing DC power lines without adding wires is technically feasible but presents challenges distinct from AC powerline communication. Common powerline communication (PLC) systems and ICs are primarily designed for AC mains and may not directly apply to low-voltage DC lines. Solutions include isolating the data signal using capacitive coupling or center-tapped transformers with appropriate turns ratios to separate data from DC power. No special ICs are strictly required if proper analog coupling and modulation techniques are used. Specific ICs like Yitran's IT700 are designed for serial communication over two-wire DC lines. Other approaches reference protocols such as X10 for powerline signaling, though typically for AC. Semiconductor manufacturers like Texas Instruments, Atmel, and Echelon offer PLC modems primarily for AC applications. Newer SoCs for powerline communication in LED lighting and home automation (e.g., Greenvity's Hybrii Mini GV7013) follow HomePlug Green Power standards but are AC-focused. Adapting AC PLC devices (e.g., PLM-24 UART) to DC lines may require custom transformer design and modulation adjustments. Overall, transmitting serial data over DC power lines involves careful signal isolation, modulation strategy, and possibly custom hardware, with some specialized ICs available for this niche.
