How to Connect Arduino and TLP to Drive Series IGBTs Without Pulse Transformer or Extra PSU
276 9
How can I drive back-to-back IGBTs from an Arduino with a TLP optocoupler without using a pulse transformer or separate gate-drive supply, and how should the emitter ground be connected?
You cannot drive the IGBT gates from the TLP without an isolated gate-drive supply; use the TLP as the isolated driver and power its output side from a small isolated DC-DC converter instead [#21680425] A pulse transformer is not a good substitute here, because the TLP already provides isolation and a pulse transformer only provides pulses, not a constant gate drive [#21680429] For back-to-back IGBTs used as an AC switch, tie the emitters together and connect them to the negative side of the DC-DC converter [#21680431] Rick reported a working implementation using an FOD3184 optocoupled driver, an SPU01L-15 isolated supply, 10 ohm resistors from the driver output to each gate, and SS14 Schottky diodes across the resistors as Miller clamps [#21680431] Use one DC-DC converter plus one driver per IGBT pair [#21680433]
  • #1 21680424
    jacob thomas
  • Need a separate isolated gate-drive supply
    #2 21680425
    Rick Curl
  • Emitter grounding issue with back-to-back IGBTs
    #3 21680426
    jacob thomas
  • Request for schematic and clarification on pulse transformer use
    #4 21680427
    Rick Curl
  • #5 21680428
    jacob thomas
  • Optocoupled driver preferred over pulse transformer
    #6 21680429
    Rick Curl
  • Using isolated DC supplies for each IGBT gate
    #7 21680430
    jacob thomas
  • FOD3184 and SPU01L-15 IGBT driver setup
    #8 21680431
    Rick Curl
  • #9 21680432
    jacob thomas
  • #10 21680433
    Rick Curl
The discussion addresses driving series-connected IGBTs using an Arduino and TLP optocoupler drivers without employing pulse transformers or separate power supplies. The TLP series provides galvanic isolation between control and power circuits, necessitating isolated gate drive power. A recommended solution involves using small isolated DC-DC converters such as the SPU01L-15 to supply the gate drive voltage. Pulse transformers at the TLP output are discouraged due to complexity and pulse distortion. For back-to-back IGBT configurations with flyback diodes, common emitter grounding can cause short circuits; thus, isolated DC supplies per IGBT or IGBT pair are advised. A practical design example uses FOD3184 optocoupled drivers with SPU01L-15 converters, tying emitters together to the negative side of the isolated supply, including gate resistors and Schottky diodes as Miller clamps for stability. For multiple AC sources or IGBT pairs, separate isolated DC-DC converters and drivers per pair are recommended to maintain isolation and proper operation.
