Voltage Across Common Point When 5V, 10V, 15V Sources Connected in Parallel
390 11
What voltage will appear at the common node if 5 V, 10 V, and 15 V sources are connected in parallel?
There is no single guaranteed voltage; it depends on the sources’ internal impedances, current limiting, and over-voltage protection, so from the information given you cannot tell the exact result [#21666394] Connecting different voltage sources in parallel can behave much like shorting them together, so the lower-voltage sources may shut down, blow a fuse, or be damaged while the higher-voltage source tries to dominate [#21666392][#21666393] If they are properly protected lab power supplies, the 15 V source may be the one that remains active, but that is not a general rule for all “voltage sources” [#21666396][#21666400] Most supplies do not use output diodes, so you should not assume reverse-current blocking unless the circuit is specifically designed for it [#21666397] In short: the parallel connection is unsafe and the node voltage is undefined without the exact source designs [#21666394][#21666392]
  • #1 21666391
    numan Hasan
  • Parallel supplies can overcurrent, shut down, or fail catastrophically
    #2 21666392
    stephen Van Buskirk
  • Parallel supplies can overvoltage and damage output parts
    #3 21666393
    stephen Van Buskirk
  • Parallel supplies will fight via internal impedance
    #4 21666394
    Steve Lawson
  • #5 21666395
    Frank Bushnell
  • #6 21666396
    JAWED MATEEN
  • #7 21666397
    stephen Van Buskirk
  • #8 21666398
    Earl Albin
  • Defends correcting incorrect technical statements
    #9 21666399
    stephen Van Buskirk
  • #10 21666400
    Steve Lawson
  • Norton source dissipates power unlike Thevenin
    #11 21666401
    Earl Albin
  • #12 21666402
    john Poole
Connecting multiple voltage sources of different voltages (5V, 10V, 15V) in parallel is generally unsafe and not recommended. The resulting voltage at the common point depends on the internal impedances, current limits, and protection features of each source. Lower voltage sources may be damaged due to reverse voltage stress, capacitor failure, or overcurrent conditions. Power supplies typically regulate their output voltage and current, but when paralleled with higher voltage sources, the lower voltage supplies can be forced into shutdown, fuse blowing, or catastrophic failure including smoke or fire. Most DC power supplies do not have output diodes to prevent backflow; diodes are usually on the AC input side for rectification. The voltage at the common node will likely be dominated by the highest voltage source if it can supply sufficient current, but this can cause damage to other sources. Safety precautions such as using current limiting, isolation diodes, or dedicated load sharing circuits are necessary. Experimental attempts without proper safeguards can result in hazardous conditions including fire and equipment destruction.
TL;DR: Paralleling 5V, 10V, and 15V sources is unsafe; diode drops are 0.6–1 V, and “Most power supplies do not have diodes in the output.” [Elektroda, stephen Van Buskirk, post #21666397]
Why it matters: This FAQ helps students, hobbyists, and engineers avoid blown supplies, fires, and injuries when mixing DC sources.
What happens if I connect 5V, 10V, and 15V sources in parallel?
They fight. The result depends on each source’s internal resistance, current limit, and protections. Expect unpredictable currents and stress. [Elektroda, Steve Lawson, post #21666394]
Is it safe to parallel different DC supplies?
No. Most supplies lack output isolation diodes, so backfeeding can overvoltage and destroy components. Avoid direct paralleling of unequal rails. [Elektroda, stephen Van Buskirk, post #21666397]
How can I test safely if I’m curious?
Don’t. If you must, keep distance and a fire extinguisher ready, and record from safety. Prioritize personal protection. [Elektroda, Steve Lawson, post #21666394]
What about batteries in parallel at different voltages?
Dangerous. Large equalization currents can cause burns or explosions. One user reports a lasting injury from a mismatch. [Elektroda, john Poole, post #21666402]
Do switch‑mode and linear supplies behave differently here?
Behavior varies by regulation design and protections. Without specifics, you cannot predict a safe outcome. [Elektroda, Steve Lawson, post #21666400]
What is a Thevenin vs. Norton equivalent?
They are equivalent circuit models: Thevenin uses a voltage source; Norton uses a current source. Both model power behavior. [Elektroda, Earl Albin, post #21666401]
What should I do instead if I need multiple voltages on one system?
Use dedicated regulators or DC‑DC converters per rail and avoid cross-connecting outputs directly. Account for diode drops if OR‑ing. [Elektroda, stephen Van Buskirk, post #21666397]
How do I OR two supplies safely with diodes?
  1. Choose diodes rated for your max current and account for 0.6–1.0 V drop.
  2. Heatsink for ~6–10 W at 10 A per diode.
  3. Verify load voltage still meets spec after the drop. [Elektroda, stephen Van Buskirk, post #21666397]
Why do people warn about smoke and flames specifically?
Directly paralleling unequal sources can exceed components’ ratings, causing thermal runaway and combustion. “Smoke” is an early warning. [Elektroda, stephen Van Buskirk, post #21666392]
How do I fix a mixed‑voltage parallel hookup I already made?
Disconnect immediately. Inspect for swollen capacitors, damaged clamps, and tripped protection. Replace stressed parts before reuse. [Elektroda, stephen Van Buskirk, post #21666393]
