Combining Two 12V 15A Power Supplies in Parallel—Current Limiter & Schottky Diode Method
435 13
Can I connect two 12V 15A power supplies in parallel to get 30A, and would output current limiters or Schottky diodes make that safe?
You generally should not parallel ordinary 12V 15A supplies unless the manufacturer explicitly says they support it, because the control loops can fight each other and the supplies may not share current evenly [#21663424][#21663428] A simple current limiter or small series resistor can help balance current, but at 15A it will dissipate a lot of heat and waste power [#21663419] The Schottky-diode method means isolating each supply output with a high-current diode so they do not back-feed each other, but you must choose rectifiers rated for the current and accept the voltage drop and diode heating [#21663420][#21663424][#21663425] One suggested alternative is to use supplies that can run in constant-current mode, set one slightly higher in voltage so it supplies the extra current while the lower-voltage unit regulates the bus [#21663422] Even then, with two 15A supplies trying to provide 30A, there is essentially no headroom and the setup depends heavily on the exact supply design and whether it is meant to operate in parallel [#21663426][#21663431]
  • Questioning current limiters for parallel 12 V supplies
    #1 21663418
    Cart McCormick
  • #2 21663419
    Calinoaia Valentin
  • #3 21663420
    Steve Lawson
  • Need for current limiting and 10 mΩ ballast resistors
    #4 21663421
    Steve Lawson
  • Use one supply in constant-current mode as backup
    #5 21663422
    Steve Lawson
  • #6 21663423
    David Figueroa
  • Parallel supplies need explicit support to avoid fighting
    #7 21663424
    Kevin Parmenter
  • Schottky diode isolation for parallel supplies
    #8 21663425
    sudheep Rc
  • No headroom leaves supplies under stress
    #9 21663426
    Steve Lawson
  • #10 21663427
    Cart McCormick
  • #11 21663428
    Ian Brown
  • Input PFC must also support parallel operation
    #12 21663429
    Peter Evenhuis
  • #14 21663431
    Sachin Sheth
Paralleling two 12V 15A power supplies to achieve a combined 30A output presents significant challenges primarily due to load sharing and control loop conflicts. Simple methods like adding low-value series resistors for current balancing are theoretically possible but impractical because of excessive heat dissipation at high currents. The Schottky diode method involves isolating each supply output with high-current Schottky diodes to prevent backfeeding and control system interference, but this also results in power loss and heat. Adjusting the supplies to closely matched voltages and using supplies with current limit (constant current, CC) and voltage adjust features can help; one supply can regulate voltage while the other operates in CC mode to share load. However, this requires supplies designed for parallel operation or CVCC (constant voltage, constant current) types. Without explicit parallel operation support, supplies may fight each other, causing instability and potential damage. Some manufacturers, like Excelsys, offer modular power supplies designed for safe parallel and series configurations. Additionally, paralleling multiple supplies can cause issues not only on the output side but also on the input side, such as power factor correction conflicts and voltage spikes. Overall, paralleling standard power supplies is complex and often not recommended unless the supplies are specifically designed for it.
TL;DR: For two 12 V/15 A supplies, use "rectifiers that can handle 20 A or more" and wire for sensing to avoid backfeed and imbalance. This method can work, but thermal behavior and control loops still matter. [Elektroda, Steve Lawson, post #21663420]
Can I safely parallel two 12 V, 15 A supplies for 30 A?
Yes, but only if you manage isolation, sharing, and control loops. Diode ORing and matched voltages can work. However, vendors that specify paralleling are safer choices. "I would not advise paralleling power supplies unless they specifically state that you can do this." [Elektroda, Kevin Parmenter, post #21663424]
What is the Schottky diode method for paralleling PSUs?
Place a high‑current Schottky diode in series with each output, then tie the diode cathodes together. The diodes block reverse current between supplies and reduce control‑loop interaction. Expect some voltage drop and heat on each diode at load. [Elektroda, sudheep Rc, post #21663425]
How do I set voltages so both supplies share current?
Without load, adjust both outputs to the same target voltage. Connect through the rectifiers. Under load, measure voltage at each rectifier anode and fine‑tune so they match closely. Differences reflect diode characteristics and wiring. [Elektroda, Steve Lawson, post #21663421]
Do I need remote sense lines when using diodes?
Yes, if your supplies have +Sense, tie it after the diode so the supply compensates the diode drop. This improves regulation at the load and reduces imbalance from differing diode drops. [Elektroda, Steve Lawson, post #21663420]
What current rating should the diodes have?
Use rectifiers rated above your expected continuous current. A practical guideline here is 20 A or more per path for 15 A loads. Higher ratings improve thermal margin and reliability in continuous duty. [Elektroda, Steve Lawson, post #21663420]
Will two identical supplies share current equally?
Not perfectly. Small voltage differences and diode characteristics cause unequal sharing. Expect one unit to carry more current unless you add sharing features. "It will work but both the power supplies will not share equal current." [Elektroda, Sachin Sheth, post #21663430]
Can I use small series resistors to balance current?
You can add low‑value resistors (e.g., 0.1 Ω), but they waste significant power at high current and run hot. Thermal dissipation and efficiency loss make this impractical for 15 A rails. [Elektroda, Calinoaia Valentin, post #21663419]
What about using CV/CC mode to share current?
Set one supply slightly higher so it enters constant current; the other regulates voltage a bit lower. The CC unit supplies extra current while the CV unit holds voltage. This requires supplies with proper CC behavior. [Elektroda, Steve Lawson, post #21663422]
How do I prevent thermal runaway in the diodes?
Add a small series resistor with each rectifier, about 10 mΩ at 5 W, to add stabilizing impedance. It helps limit the heating spiral when one diode’s forward drop falls with temperature. [Elektroda, Steve Lawson, post #21663421]
Is running both supplies at their max current okay?
Avoid operating at zero headroom. If you need 30 A from two 15 A units, both run at limit, increasing stress and reducing reliability. Derate or choose higher‑current, paralleled‑ready models. [Elektroda, Steve Lawson, post #21663426]
Are there risks beyond the outputs when paralleling?
Yes. Inputs can also interact. Poorly coordinated front ends, such as PFC stages, may fight and create harmful voltage spikes, causing failures. Large multi‑supply systems have burned out this way. [Elektroda, Peter Evenhuis, post #21663429]
Will adding external current limiters solve sharing?
External limiters help only if the supplies’ internal control loops tolerate parallel operation. Without vendor support for paralleling, loops may interfere and cause instability or damage. Use modules designed for sharing. [Elektroda, Kevin Parmenter, post #21663424]
What are +Sense/-Sense lines on a power supply?
Sense lines measure voltage at the load point rather than at the supply terminals. When used after the series diode, the supply raises output slightly to overcome diode drop, improving regulation at the load. [Elektroda, Steve Lawson, post #21663420]
Quick 3‑step: how do I wire and verify two PSUs with diodes?
  1. Adjust both supplies to the same voltage with no load. 2. Wire each output through its own Schottky diode, tie cathodes, connect load and sense after diodes. 3. Under load, measure anode voltages and tweak for close matching. [Elektroda, Steve Lawson, post #21663421]
Do I need supplies explicitly rated for paralleling?
It is strongly recommended. Parallel‑ready units include current‑share features and avoid control‑loop conflicts. Simple diode ORing works, but it wastes power and can still mis‑share under dynamics. [Elektroda, Kevin Parmenter, post #21663424]
Should I worry about rectifier heating and sizing?
Yes. Sustained 15 A loads heat diodes; select ample current rating and heatsinking. As one expert put it, use rectifiers “that can handle 20 A or more.” [Elektroda, Steve Lawson, post #21663420]
