Best motor type for adjustable 1–24 rpm clay mixer: AC with VFD or DC with controller?
273 11
How can I build a clay mixer drive with adjustable speed from 1 to 24 rpm while keeping torque, and should I use an AC or DC motor?
Use a 3-phase motor with a variable frequency drive if you want the best low-speed torque control; a VFD can give full torque at whatever speed you need, within reason [#21666715] If you stay with AC, use a proper triac motor speed controller, not a light dimmer, because triac controllers are the correct speed-control method for single-phase AC motors [#21666716][#21666718] For a DC motor, the matching solution is a PWM DC motor speed controller, which is also cheap and readily available [#21666716] Single-phase AC equipment is generally cheaper and easier to find, and a mains power-tool speed controller is essentially the same kind of circuit used for AC motor speed control [#21666718] Keep the electrical parts dry and well protected because the mixer uses water and electricity do not mix [#21666714]
  • Need for variable-speed motor with gearbox
    #1 21666712
    hadi makoui
  • #2 21666713
    Pothuganti Balaiah
  • #3 21666714
    Peter Evenhuis
  • #4 21666715
    David Adams
  • #5 21666716
    Frank Bushnell
  • #6 21666717
    hadi makoui
  • Triac AC speed control for single-phase motors
    #7 21666718
    Frank Bushnell
  • #8 21666719
    Mark Harrington
  • DC motor speed control with memory and digital readout
    #10 21666721
    Mark Harrington
  • #11 21666722
    hadi makoui
  • #12 21666723
    Mark Harrington
The discussion addresses the choice between AC and DC motors for an adjustable-speed clay mixer requiring 1–24 rpm. A 1.5 hp single-phase AC motor running at 1420 rpm can be geared down to 24 rpm, but achieving 1 rpm requires motor speed reduction without torque loss. For speed control, single-phase AC motors can be managed using triac-based speed controllers, which modulate the AC waveform via phase angle control (a form of PWM), suitable for motors up to about 2 kW. These controllers are inexpensive, user-friendly, and commonly used in power tools. DC motors require PWM DC motor speed controllers for efficient speed regulation. Three-phase AC motors combined with variable frequency drives (VFDs) offer precise speed control with full torque across a wide speed range but may be more complex and costly. Safety considerations emphasize protecting electrical components from moisture due to the wet clay environment. Several technical resources and application notes on triac controllers, VFDs, and DC motor control circuits were shared to assist in implementation.
TL;DR: Need 1–24 rpm? “Rotational speed … must be adjustable between 1 and 24 rpm.” Use a geared drive plus either a VFD on a 3‑phase motor or a proper AC/DC controller, not a lamp dimmer. [Elektroda, hadi makoui, post #21666712]
Why it matters: This FAQ helps makers choose a safe, torque‑capable, low‑speed drive for clay mixers.
What motor type works best for a clay mixer at 1–24 rpm?
Use a 3‑phase induction motor with a VFD plus a gearbox. The VFD gives controllable speed and strong low‑speed torque. Add mechanical reduction to hit 1–24 rpm without stalling. “VFD will give you full torque … within reason.” [Elektroda, David Adams, post #21666715]
Can I slow an AC motor with a light dimmer?
Do not use a household lamp dimmer. It is not designed for motor loads, has poor control, and creates safety risks. Use a purpose‑built motor controller instead. “A light dimmer is for light not for speed control.” [Elektroda, Peter Evenhuis, post #21666714]
How do I control speed on a single‑phase AC motor?
Use a triac‑based AC motor speed controller. These phase‑angle controllers are common in power tools and available as plug‑in modules, offering simple, low‑cost adjustment. [Elektroda, Frank Bushnell, post #21666716]
How do I control speed on a DC motor?
Use a PWM DC motor speed controller. PWM varies the average voltage while keeping efficiency high, giving smooth, wide‑range speed control and good torque. [Elektroda, Frank Bushnell, post #21666716]
What is a VFD and why choose one here?
A Variable Frequency Drive changes the frequency and voltage to a 3‑phase motor, letting you dial speed and maintain torque. It’s well‑suited to mixers needing low, adjustable rpm. “Full torque … within reason.” [Elektroda, David Adams, post #21666715]
Will a triac controller keep torque at 1 rpm on an induction motor?
Not reliably. Phase‑angle control reduces voltage and torque, which can cause stalling at very low speeds. For strong torque near 1 rpm, use gearbox reduction plus a VFD. “Within reason” applies at very low rpm. [Elektroda, David Adams, post #21666715]
Is PWM the same idea as chopping AC with a triac?
Yes, in principle. A triac controller “chops” the AC waveform similar to PWM on DC, altering effective voltage to change speed. [Elektroda, Frank Bushnell, post #21666718]
What gearbox ratio do I need from 1420 rpm to 24 rpm?
Approx. 59:1 (1420 ÷ 24 ≈ 59). Add more reduction for a 1 rpm minimum while keeping the motor in an efficient speed range. [Elektroda, hadi makoui, post #21666712]
What mains supply should I plan around?
Design for single‑phase 220 V, 50 Hz if that’s your available supply. You can also consider a 3‑phase motor with appropriate control hardware. [Elektroda, hadi makoui, post #21666717]
Are off‑the‑shelf single‑phase speed controllers available for retrofits?
Yes. Example tool‑style controllers exist for single‑phase AC motors up to about 2 kW and can be used in simple builds. [Elektroda, Frank Bushnell, post #21666718]
What’s the cheapest path to variable speed right now?
For simplicity and low cost, use a triac AC controller for single‑phase motors or a PWM controller for DC motors. Both are widely available and inexpensive. [Elektroda, Frank Bushnell, post #21666716]
How should I approach safety around wet clay and electrics?
Keep all electrical parts dry and sealed. Use proper enclosures, strain relief, and ground fault protection. Water and electricity together can kill. [Elektroda, Peter Evenhuis, post #21666714]
Can I adapt a power‑tool style controller to my mixer motor?
Yes, many power tools use similar triac speed controls. A compatible module can provide knob‑type adjustment for AC motors. Ensure current rating matches your motor. [Elektroda, Frank Bushnell, post #21666718]
Which controller should I avoid for induction motors?
Avoid plain lamp dimmers. Use controllers designed for motor loads. Dedicated triac motor controllers address phase control, surge, and protection. [Elektroda, Mark Harrington, post #21666720]
How do I set up a simple AC speed control safely? (3‑step How‑To)
  1. Choose a triac motor controller rated at or above your motor’s current.
  2. Mount it in a ventilated, splash‑proof enclosure with strain relief.
  3. Wire line‑in and motor‑out per the module diagram; test at no‑load, then under clay load. [Elektroda, Frank Bushnell, post #21666718]
What power level am I dealing with at 1.5 hp?
About 1.12 kW (1 hp ≈ 0.746 kW). Ensure controller and wiring comfortably exceed this rating plus startup surge current. [Elektroda, hadi makoui, post #21666712]
