Speed control for motor salvaged from vintage electrical sewing machine
576 10
How can I slow down a 240V brushed AC sewing machine motor for use as a bench drill with a cheap hand-operated speed controller instead of a foot pedal?
A cheap lamp dimmer should work on a brushed AC motor, but speed regulation under changing load will be poor, so an SCR-based controller is the better solution [#21683330][#21683332] The recommended circuit uses a TIC106D SCR to apply pulsed DC to the motor, with the motor placed below the SCR so the back EMF provides feedback and helps stabilize speed [#21683332][#21683336][#21683338] This type of controller can run a brushed motor at about 70% or more of full AC speed, and it is especially suitable if you need a simple knob-controlled bench speed controller [#21683338] It is mains circuitry, so it must be treated with great care, and the SCR metal tab may be live/anode [#21683332][#21683335] The inductor and capacitor for interference suppression can be the hardest parts to source, but they may be salvaged from old switched-mode power supplies [#21683338] If you want an off-the-shelf alternative, a variable transformer would work well but is heavy and expensive [#21683333]
  • Light dimmer may work as a cheap speed controller
    #1 21683329
    Michelle OBrien
  • Dimmer or wire-wound resistor for motor speed control
    #2 21683330
    David Ashton
  • #3 21683331
    Michelle OBrien
  • SCR speed regulator with back-emf feedback
    #4 21683332
    David Ashton
  • #5 21683333
    PeterTraneus Anderson
  • #6 21683334
    Michelle OBrien
  • #7 21683335
    Alan Winstanley
  • #8 21683336
  • Elektor archive circuit found and shared privately
    #9 21683337
    David Ashton
  • SCR controller gives brushed AC motors partial DC pulses
    #10 21683338
    David Ashton
  • #11 21683339
    Michelle OBrien
A vintage Singer electric sewing machine motor (240V, 50Hz, 60W) with a brushed AC design produces excessive speed for use as a drill power source. A simple, cost-effective speed control solution is sought, preferably with a hand-operated knob rather than a foot pedal. A standard electric light dimmer switch can be used to control speed on brushed AC motors, as it functions via pulse width modulation, but may offer limited speed regulation under varying loads. An alternative is a specialized speed regulator circuit using a silicon controlled rectifier (SCR), specifically a TIC106D SCR, which applies pulsed DC to the motor and provides better speed stability through back EMF feedback. This circuit, originally published in Elektor magazine (July/August 1983 issue) and available on Electroschematics.com, requires careful assembly and mains safety precautions. Other options include using a rotary wire-wound variable resistor similar to the original foot pedal resistor or powering the motor with a low-voltage DC supply (e.g., 12V DC) to achieve slower speeds. Variable transformers can also control speed but are heavy and costly. Components like inductors and capacitors for interference suppression may be salvaged from old power supplies. The discussed solutions emphasize safety due to mains voltage involvement and the need for proper insulation, especially around the SCR's metal tag (anode).
