[Guide] How to Draw a NOT Gate Circuit Using Only a Diode and Resistor for Homework
654 9
How can I design a NOT gate using only a diode and a resistor for homework?
You cannot make a NOT gate using only a diode and a resistor; the thread says that a transistor and a resistor should be used instead [#21667037] [#21667042] A simple inverter can be made with a common-emitter transistor stage: feed the input to the base and take the inverted output from the collector with respect to ground [#21667039]
  • #1 21667033
    Emily Alice
  • #2 21667034
    Umair Aftab
  • #3 21667035
    David Adams
  • #4 21667036
    Steve Spence
  • #5 21667037
    Farhan Ali
  • Homework questions should get straightforward answers
    #6 21667038
    Peter Owens
  • #7 21667039
    sumit Gogna
  • #8 21667040
    Emily Alice
  • #9 21667041
    Mark Harrington
  • #10 21667042
    Emily Alice
The discussion addresses a homework question about designing a NOT gate circuit using only a diode and a resistor. Multiple contributors clarify that it is not feasible to construct a NOT gate solely with a diode and resistor, as a diode cannot invert logic signals. Instead, a transistor-based inverter circuit is recommended, typically using a common emitter transistor configuration with a resistor to achieve logical inversion. The input signal is applied to the transistor base, and the inverted output is taken from the collector relative to ground. References to online electronics theory resources are suggested for further study. The consensus is that a transistor and resistor are necessary components for implementing a NOT gate, not just a diode and resistor.
