Best Way to Achieve Stable 9V DC Output: 9V Battery vs Regulated DC Power Supply
276 7
  • #1 21675782
    jr don
  • Low-noise battery plus LDO tradeoff
    #2 21675783
    Dean Franks
  • Clarify stability, noise, load, and environment requirements
    #3 21675784
    richard gabric
  • Need low-noise 9 V with minimal drift
    #4 21675785
    jr don
  • #5 21675786
    Justin Spencer Mamaradlo
  • Check meter resolution and battery temperature coefficient
    #6 21675787
    richard gabric
  • Load regulation concerns for voltage references
    #7 21675788
  • #8 21675789
    richard gabric
To achieve a stable 9V DC output with minimal noise and voltage drift, the choice between a 9V battery and a regulated DC power supply depends on the specific requirements for voltage accuracy, noise level, load variation, and environmental conditions. Low internal resistance batteries such as NiMH or LiPoly provide very low noise but their voltage varies with temperature and load, and they do not maintain a precise voltage level. Using a low-dropout (LDO) linear regulator with such batteries can improve voltage stability and regulation at the cost of some added noise and reduced efficiency. DC power supplies can be designed to minimize ripple and noise effectively, but achieving ultra-low noise requires careful design. For loads in the range of 100-400 kΩ with slow resistance changes, an LDO regulator is recommended for low noise (down to ~60 µVrms) and good load regulation. Battery voltage temperature coefficients (e.g., ~1 mV/4°C for alkaline) and measurement resolution should be considered to ensure stability over environmental changes. Bandgap voltage references may not regulate well under high load currents typical of the specified load range. Overall, an LDO regulator combined with a low ESR battery offers a good compromise for low noise and stable voltage in this application.
