Best way to power USB amplifier: Nokia phone battery vs 6V battery for 5V supply
282 10
How can I power a small USB-powered amplifier from a battery instead of a USB port?
Power it from a regulated 5V source made from your battery, not directly from the battery itself. If your source is 6V, one suggestion is a low-quiescent-current 5V LDO such as the MCP1703-5002E/DB (up to 250 mA) or LP2950-50LPRE3 (up to 100 mA) [#21660329] However, a 5V LDO may stop regulating as the battery voltage sags, because typical dropout is about 300 mV and a 6V battery can dip during discharge or load transients [#21660336] For a more reliable setup, use a SEPIC, buck-boost, or flyback converter; LM2587-5.0 was suggested as an example [#21660336]
  • #1 21660327
    Imran Haq
  • #2 21660328
    Siraj A
  • Low-quiescent-current 5 V LDO recommendations
    #3 21660329
    Steve Lawson
  • #4 21660330
    Siraj A
  • #5 21660331
    Steve Lawson
  • #6 21660332
    Imran Haq
  • #7 21660333
    Imran Haq
  • #8 21660334
    Steve Lawson
  • Need amplifier specs and intended use
    #9 21660335
    Per Zackrisson
  • Buck-boost converter recommended over 5V LDO
    #10 21660336
    StrykerTECH
  • #11 21660337
    Imran Haq
The discussion addresses powering a small USB amplifier using batteries instead of a USB power supply. Suggestions include connecting four AA batteries to provide the required voltage and using low dropout (LDO) voltage regulators to achieve a stable 5V output from a 6V battery source. Specific LDO regulators recommended are the MCP1703-5002E/DB (surface mount, up to 250mA) and the LP2950-50LPRE3 (through-hole, up to 100mA). However, concerns were raised about the dropout voltage of LDOs causing failure as the battery voltage drops during discharge. An alternative solution proposed is using DC/DC converters such as SEPIC, buck-boost, or flyback converters, which maintain a stable 5V output even if the input voltage fluctuates above or below 5V. The National Semiconductor LM2587-5.0 is cited as an example of such a converter. The importance of consulting the amplifier’s datasheet for built-in voltage regulation and specific power requirements was emphasized. Practical considerations include component availability depending on location and the amplifier’s intended application (audio vs. measurement).
