Designing a 0-20uA High Precision Voltage to Current Converter Circuit
384 9
How can I build a voltage-to-current converter that produces 0–20 µA for testing a photodiode-based position-control feedback circuit?
Use an op-amp based voltage-controlled current sink to replace the photodiode outputs; Steve provided a custom circuit for this and said it can be simulated [#21667442] He confirmed the circuit will give 0–20 µA with about ±20 nA variation [#21667444] For the op-amp, he suggested the MC33172, which provides two op-amps for your two current sources [#21667444] He also assumed a 0–2 V input range and noted that the required resistor R1 is set from the input-voltage range; the MC33172’s 2.0 mV input offset is usually not a problem, though it may matter near 20 nA [#21667444]
  • #1 21667436
    ganesh Bhosle
  • #2 21667437
    Frank Bushnell
  • #3 21667438
    ganesh Bhosle
  • #5 21667440
    Steve Lawson
  • #8 21667443
    ganesh Bhosle
  • MC33172 suggested for dual current sources
    #9 21667444
    Steve Lawson
  • #10 21667445
    ganesh Bhosle
The discussion focuses on designing a high precision voltage-to-current converter circuit with an output current range of 0-20µA, intended to replace photodiode sensors in a position control application. The user requires a voltage-controlled current sink or source to simulate photodiode outputs for testing purposes. Suggested solutions include constant current source circuits and voltage-controlled current sink designs using operational amplifiers. Key advice highlights using the MC33172 dual op-amp for implementing two current sources, with attention to input offset voltage (approximately 2.0mV) and component selection based on the input voltage range (assumed 0-2V). Reference circuits and simulation tools were provided to aid design and verification. Offset compensation may be necessary if operating near the 20nA resolution level.
