Best Tools and Methods for Making Clean PCB Track Cuts Efficiently
357 6
  • #1 21667485
    William Makinen
  • Heating a trace section to lift it cleanly
    #2 21667486
    stephen Van Buskirk
  • 3.5 mm drill bit and chisel-tip cleanup
    #3 21667487
    Frank Bushnell
  • #4 21667488
    Steve Lawson
  • #5 21667489
    Frank Bushnell
  • #6 21667490
    susanc woodruff
  • #7 21667491
    Steve Lawson
Several methods for making clean and efficient PCB track cuts were discussed. Using an Exacto knife is common but slow and requires frequent blade replacement or sharpening. One technique involves making two close cuts and heating the copper trace with a soldering iron to lift the section by breaking down the adhesive, even through soldermask. For PCB stripboard, a 3.5 mm drill bit held by hand is a standard tool to remove unwanted track holes, followed by a sharpened chisel-tip screwdriver to clean remaining copper edges and create tidy gaps. Power tools such as a Dremel rotary tool with a cylindrical steel carving bit (~1/8" diameter) or a battery-powered engraver with a diamond burr head offer faster, effective track removal. These tools are favored for speed and precision in carving copper tracks. Avoiding damage to adjacent tracks is emphasized, with solder repair suggested if accidental damage occurs.
