Best Methods for Cleaning Printed Circuits: Salicin Spirit, Diluted Alcohol & More
achilles 31251 9
What is the best way to clean grease and dirt from a printed circuit board, and can I use spirit or diluted drinking alcohol without removing the rosin layer?
Spirit or alcohol is the best gentle cleaner for a PCB that already has a rosin layer, and it should remove grease without stripping the coating as aggressively as stronger solvents [#1117373][#1125084] Propanol was also recommended, especially for cleaning soldered boards and SMD areas, while an ultrasonic bath with a cleaner or propanol is suggested for hard-to-reach places like under BGAs [#1116738][#1117451] If you need stronger cleaning, acetone, toluene, or nitro will remove dirt and rosin well, but they can also remove the rosin coating and must be used carefully around components [#1120902][#1117451] For freshly etched boards, one reply recommends very fine wet water sandpaper, then covering the board with dissolved rosin in nitro [#1118881]
  • #1 1116497
    achilles
    As in the subject, what measures can be used for this, what are the best?
    Is it possible, for example, to use salicin spirit or drink alcohol (of course slightly diluted ;) )?
  • #2 1116511
    SQ9PXB
    Help: 75
    Rate: 59
    various types of powders are good for degreasing, only small ones so as not to scratch too much copper, water-based paper 1000 is also good, spirit as much as possible :) especially for cleaning the marker pen after etching
  • #3 1116738
    Jethro
    Help: 28
    I agree with my colleague Achilles, alcohol is good for this, but it will not reach, for example, an integrated circuit, e.g. under the so-called BGA. In such cases, an ultrasonic bath and a liquid, e.g. a cleanser or propanol, i.e. also alcohol, are used. If you want to wash off the felt-tip pen after etching, various cifs or solvents wash it off well.
  • #4 1116828
    kamahonda
    Rate: 22
    This is the plate not yet armed?
  • #5 1117373
    wołodzia
    in my opinion, spirit is the best cleaning agent
    or extraction gasoline, he personally uses the first variant
  • #6 1117451
    Błażej
    Help: 1923
    Rate: 3627
    If it is a freshly etched plate and ready for assembly, I recommend steel wool, such as for cleaning copper pipes before brazing.
    if it's a PCB after soldering and you want to get rid of rosin residues, it depends on how complicated the PCB is. Through-hole assembly with almost no limitations. I even used nitro. you just have to be careful not to splash the side of the elements. Surface printing: propanol, spirit, special chemicals.
    Nitro will remove all rosin, while the spirit, which works a bit slower, will dissolve it and smear it on the plate, which will give a kind of protective coating.
  • #7 1117561
    elektronik321
    Help: 29
    Rate: 51
    if the tile has a secondary perceptible oxides, you can use a sponge used to clean copper pipes, the sponge works on the principle of fine sandpaper
  • #8 1118881
    kamahonda
    Rate: 22
    I wipe the freshly etched plate with very fine water sandpaper (the kind used for sanding cars before painting), wet of course, then dry and cover with a thin layer of dissolved rosin in a nitro solvent. Soldering after such a procedure is great.
  • #9 1120902
    MaxFall1
    I clean with acetone (washing varnish) or toluene (for dirt and grease)
  • #10 1125084
    achilles
    Thanks for explaining the topic to me. I did not add at the beginning that I mean mainly removing grease from the surface of the plate, which is already covered with a layer of rosin. I meant a measure that will not remove it. I wasn't sure about the spirit.
    Thanks and regards
The discussion focuses on effective methods for cleaning printed circuit boards (PCBs), particularly in removing grease and residues without damaging the components. Various cleaning agents are recommended, including salicin spirit, diluted alcohol, propanol, acetone, and toluene. Users suggest that while alcohol is effective, it may not penetrate areas like BGA (Ball Grid Array) components, where ultrasonic baths with specialized cleaners are preferred. For freshly etched boards, fine water sandpaper and nitro solvent are recommended for preparing the surface before soldering. Steel wool and sponges designed for cleaning copper pipes are also mentioned for removing oxides and residues. The importance of using appropriate cleaning methods based on the PCB's condition and assembly type is emphasized.
