Removing Excess Tin from a Plate: Cost & DIY Alternatives for Clearing Closed Paths
pgp 31842 9
How can I remove excess solder from a PCB when it spills and bridges the traces?
Use a desoldering pump for larger amounts of solder, and use copper braid/desoldering wick soaked in rosin for precise cleanup [#810313][#810423][#817776] A home-made wick can be made from the braid taken from an antenna/coax cable, also soaked in rosin [#810313] For small solder bridges, you can carefully cut or scrape the excess with a knife or screwdriver [#810327] The thread says these tools are available in electronics stores, but it does not give an exact price [#810374]
  • #1 810302
    pgp
    Level 19  
    Help: 6
    Rate: 17
    How to remove excess tin from a plate that spills and closes paths. I've already seen special pullers. How much do they cost? Are there any other "home" ways to remove excess tin as effectively as possible?
  • #2 810313
    beatom
    Help: 421
    Rate: 877
    a suction device or a special copper line soaked in rosin is used. The rope can be replaced with a braid pulled from the antenna cable ("concentric"), also it must be soaked in rosin.
  • #3 810316
    heynow
    Level 19  
    Help: 8
    Rate: 44
    I would suggest an ordinary suction device
  • #4 810327
    adi-niunio
    Help: 9
    Rate: 33
    if it is a small "thread" of tin that contains these paths, it is enough to cut it or gently scratch it with a knife or a screwdriver.
    I do it like that
  • #6 810423
    brodziek
    Help: 11
    I recommend a suction device or a copper braid for precise extraction
  • #9 817684
    BOSSMAN26
    Rate: 42
    To clarify the use of the screen, you need to stretch it wide, increase its mesh and soak the rosin, but without exaggeration, because when you remove the tin, you will have a rosin tonol. Put the properly prepared screen on the tin that is lying around and heat up the soldering iron. The screen can be used many times, it is only necessary to heat it up and by shaking it with a vigorous movement of tin knocks it is still liquid.
  • #10 817776
    milik
    Help: 71
    Rate: 58
    Braided line is perfect for desoldering chips. Pgp remember, no extractor is as accurate as braided line. On the other hand, the sucker is great at sucking out larger amounts of tin, such as resistors, diodes, etc.
To remove excess tin from a plate that obstructs paths, various methods can be employed. A suction device or a copper braid soaked in rosin are commonly recommended tools for effective tin removal. For smaller threads of tin, cutting or gently scratching with a knife or screwdriver may suffice. The cost of suction devices can vary, and they are available at electronics stores. A braided line is particularly effective for desoldering chips, while suction devices are better for larger amounts of tin. Proper preparation of the braid or screen, including soaking in rosin and heating with a soldering iron, enhances their effectiveness in clearing tin.
