Meaning of GND and ADJ Symbols in Electronic Circuit Diagrams
1263 8
  • #1 21667556
    Vishnu Vijay P
  • #2 21667557
    Steve Spence
  • #3 21667558
    David Adams
  • Critique of buyers who cannot read schematics
    #4 21667559
    Mark Harrington
  • Defends beginner questions and criticizes belittling replies
    #6 21667561
    Jason Tribe
  • Hardline argument for blunt technical criticism
    #7 21667562
    Mark Harrington
  • #8 21667563
    Mark Harrington
  • #9 21667564
    Jason Tribe
In electronic circuit diagrams, the symbol "GND" stands for ground, which typically refers to the reference point in the circuit and is often the negative terminal of the power supply. There are different types of grounds including earth ground, signal ground, and chassis ground, with the latter being the one commonly depicted in many schematics. The symbol "ADJ" denotes an adjustment pin, frequently found on adjustable voltage regulators, and is used to vary the output voltage. It can also refer more generally to adjustment points involving variable resistors, capacitors, or inductors. The discussion also referenced external resources such as the Wikipedia page on electrical ground for further reading.
