Meaning of mass in electronics—Is GND (ground) the same as mass or minus?
jacek89 31364 4
  • #1 3571286
    jacek89
    Sorry to ask such a trivial question, but nowhere can I find an intelligible answer. :(
    What does the electronics mean by saying " mass "?
    What exactly is mass in electronics?
    Regards,
    Jack
  • #3 3571342
    sadamb
    Help: 61
    Rate: 18
    The point against which the potentials in an electronic system are measured
    (reference)
    jony
    Electronics specialist
    Help: 1823
    Rate: 885
    If the system is powered by a battery or a non-symmetrical power supply, the ground is usually the negative pole of the battery or power supply. So we connect all these black thick lines in the diagram to the negative pole of the power supply.
    https://www.elektroda.pl/rtvforum/topic693740.html
  • #5 3571484
    jacek89
    This is exactly what I meant :!: :D :D
    Thanks a lot :D
