How can I build a 12V 3A battery charger from a 220V mains supply?
Use a step-down transformer from the 220V input and build around a 12V charger circuit such as the one linked in the thread [#21667614][#21667618] If you need a smart charger, decide whether you want a 3-stage charge profile or a simple automotive trickle charger first [#21667611] You also need to think about what happens when the battery reaches full charge, because charging should not continue unchecked [#21667614] One suggested method for handling full charge is a diversion load circuit [#21667614]
Hi, think about using a step down transformer. The buck converter I posted I am using for a wind turbine. Then you have to consider what happens when the battery reaches full charge. One method is to use a diversion load circuit. Why do you want to fabricate the charger?
The discussion focuses on designing a 12V, 3A battery charger powered from a 220V AC input. Key considerations include whether to implement a simple automotive-style trickle charger or a more advanced smart charger with a three-stage charging profile. Suggestions include using a step-down transformer or a buck converter for voltage regulation. Managing the battery's full charge state is critical, with options such as diversion load circuits to prevent overcharging. A reference circuit link is provided for practical guidance. The project is intended as an educational exercise in battery charger fabrication. AI summary based on the discussion. May contain errors.
