How Does an IR Remote Control Circuit Work? Explanation with Diagram
399 12
How does an IR remote control circuit work, and can it be used securely for switching home devices?
An IR remote control circuit can switch devices, but the simple circuit discussed is not coded, so any remote can trigger it and it is not secure [#21667702] For security-aware use, you should move to a PIC microcontroller and use IR codecs such as Sony IR or Philips RC5, or even a rolling-code approach [#21667703] If it is only for a private home-brew system, a basic coded setup may still be acceptable, but the sensors should be camouflaged so criminals cannot easily identify the system [#21667705]
  • #1 21667696
    NEEL KANTH SHARMA
  • #2 21667697
    Adeyeye Jelil
  • #3 21667698
    Steve Lawson
  • #4 21667699
    Frank Bushnell
  • #5 21667700
    Adeyeye Jelil
  • #6 21667701
    Adeyeye Jelil
  • #7 21667702
    Mark Harrington
  • Recommend PIC microcontrollers with Sony IR and RC5 codecs
    #8 21667703
    Mark Harrington
  • #9 21667704
    Mark Harrington
  • Basic IR security coding should suffice for home use
    #10 21667705
    Frank Bushnell
  • #11 21667706
    Steve Lawson
  • How to add coded output to a simple remote
    #12 21667707
    Adeyeye Jelil
  • #13 21667708
    Adeyeye Jelil
The discussion centers on the working principles of IR remote control circuits, including a request for an explanatory diagram. The circuit demonstrated basic IR remote functionality but lacks coded output, making it insecure for applications like home security systems controlling doors or lights. For enhanced security, integration of microcontrollers such as PIC micros with IR communication protocols like Sony IR and Philips RC5 codecs is recommended. More advanced security features include rolling codes, encryption techniques, and alternative wireless technologies like Bluetooth, Wi-Fi, and RFID. The conversation highlights the importance of considering hacking and code-cracking vulnerabilities in security designs. While simple IR remote circuits can suffice for private home use due to low risk of sophisticated attacks, commercial or high-security applications require robust coding and encryption. The discussion also reflects on the learning process for electronics enthusiasts and the need for mentorship in circuit design and security implementation.
TL;DR: Most IR remotes modulate light at 38 kHz; “most consumer IR remotes use a 38 kHz carrier.” Build with a demodulating receiver, decode the protocol, then drive a relay or MCU. [Vishay, 2013]
Why it matters: This FAQ helps beginners wire, code, and secure simple IR remote circuits for switching lights, doors, or DIY home projects.
  • Typical carrier: 36–40 kHz; 38 kHz is most common in consumer gear. [Vishay, 2013]
  • Typical indoor range: Approx. 5–10 m line‑of‑sight with a 940 nm LED and matched receiver. [Vishay, 2013]
  • Popular IR protocols: NEC, RC‑5, Sony SIRC; data rates are often around 1–3 kbps. “IR remote control.” [Wikipedia]
  • Uncoded receivers accept any remote; use coded or rolling code designs for security‑aware uses. [Elektroda, Mark Harrington, post #21667702]
How does an IR remote control circuit work?
A handheld remote blinks a 940 nm IR LED with data riding on a 38 kHz carrier. A demodulating receiver module filters, AGC‑amplifies, and demodulates that carrier to logic pulses. A decoder (IC or microcontroller) interprets the protocol and drives loads through a transistor or relay. “Most consumer IR remotes use a 38 kHz carrier,” so select a matching receiver. [Vishay, 2013]
Can I use this circuit to switch lights, doors, or other home loads?
Yes. A basic IR receiver can toggle relays to control bulbs, door strikes, or low‑voltage devices. However, if the receiver is uncoded, any remote using the same carrier may trigger it. “It will however work but is not secure by any means.” Add coding before using it for security‑aware control. [Elektroda, Mark Harrington, post #21667702]
Is a basic IR remote safe enough for home security?
It can work for hobby setups, but treat it as low security unless you add coding and tamper measures. One forum expert notes burglars focus on higher‑value targets; still, conceal sensors so the system’s nature is unclear. Use coded protocols and lockouts to reduce spoofing risk. [Elektroda, Frank Bushnell, post #21667705]
How do I add a coded output so only my remote works?
Use a microcontroller (e.g., PIC, AVR, Arduino) to decode a specific protocol like Sony SIRC or Philips RC‑5, and reject unknown frames. For stronger protection, implement challenge/response or rolling code. “Migrate to PIC micro and look at Sony IR in and Philips RC5 codecs.” [Elektroda, Mark Harrington, post #21667703]
What is Philips RC‑5?
RC‑5 is a bi‑phase (Manchester) encoded IR protocol defined by Philips. It typically uses a 36 kHz carrier with 14‑bit frames (toggle, address, command). It’s simple, well‑documented, and widely supported in hobby libraries and consumer devices. [“Philips RC‑5”]
What is Sony SIRC?
Sony SIRC is a pulse‑width encoded IR protocol family (12/15/20‑bit variants) commonly using a 40 kHz carrier. It defines address and command fields and repeats commands while a key is held. Many universal remotes and decoder libraries support SIRC. [“Sony SIRC”]
What’s rolling code and why is it more secure than fixed codes?
Rolling code changes the transmitted code every use, preventing simple replay attacks. Transmitter and receiver share a secret and a moving counter; only fresh codes authenticate. It’s the basis of systems like KEELOQ for remotes and access control. [Microchip, 2011]
How do I build a simple Arduino IR receiver and read remote codes?
  1. Connect a 38 kHz receiver (e.g., TSOP38238) to 5V, GND, and a digital pin through its OUT.
  2. Install the IRremote library; load the Receive example.
  3. Open Serial Monitor, press remote keys, note protocol and codes for your sketch logic. Use a logic‑level MOSFET or relay module to switch loads. [Ken Shirriff, IRremote]
Why does my IR receiver misfire in sunlight or near CFL/LED lamps?
Strong ambient IR or lamp flicker can saturate the receiver’s AGC or mimic carrier bursts, causing false triggers or dropouts. Shield the sensor, use a proper 38 kHz module with narrow bandpass, and avoid direct sunlight. Some modules include improved AGC to resist interference. [Vishay, 2013]
What range should I expect, and how can I extend it?
Expect about 5–10 m indoors line‑of‑sight with a 940 nm LED and a matched 38 kHz receiver. Improve range by increasing LED current within datasheet limits, narrowing the LED beam, and ensuring clean line‑of‑sight. Use fresh batteries and proper carrier frequency matching. [Vishay, 2013]
Bluetooth or Wi‑Fi vs. IR: which is better for smart control?
IR is simple, cheap, and one‑way. Bluetooth and Wi‑Fi add encryption, two‑way feedback, and no line‑of‑sight requirement. For security‑aware control, consider BLE or Wi‑Fi and authenticated protocols. A forum expert suggested exploring Bluetooth and Wi‑Fi for modern systems. [Elektroda, Mark Harrington, post #21667703]
How should I place or hide sensors for home projects?
Mount receivers behind dark IR‑transparent windows, inside bezels, or near existing indicators. Avoid direct sunlight and reflective surfaces. Concealing sensor placement reduces tampering and keeps the system’s design unclear to casual attackers, as one poster advised. [Elektroda, Frank Bushnell, post #21667705]
What is RFID, and should I combine it with IR for access control?
RFID uses radio to identify tags without line‑of‑sight. You can pair RFID for identity and IR for command confirmation. If you use RFID, add encryption and an override method to handle card or reader failures, as highlighted in the forum discussion. [Elektroda, Mark Harrington, post #21667703]
Which receiver frequency should I choose?
Select a receiver tuned to your remote’s carrier, typically 38 kHz. Using the wrong center frequency reduces range and increases false triggers. Match 36, 38, or 40 kHz modules to your protocol and transmitter, with 38 kHz being the most common choice. [Vishay, 2013]
