How to Make Remote Control Home Appliances Using IR Sensor and Arduino?
483 11
How can I build a simple IR-based remote control switch to turn a 220V bulb or fan on and off?
You can build it from an IR receiver stage that detects modulated IR pulses, then drive a transistor and relay to switch the mains load, using the linked IR remote-control switch circuit as a starting point [#21678041] The receiver should not just look for steady IR; it should respond to a pulse train at a specific frequency, such as 5 kHz, so sunlight and room lights do not falsely trigger it [#21678041] If you want a more robust code-based design, use encoder/decoder ICs such as HT12E and HT12D so the circuit only responds to the correct pulse pattern [#21678041] Be aware that TV/AC remotes use proprietary IR protocols, and a simple receiver board often contains a microcontroller with code to decode those signals [#21678038] Also take safety seriously because you are switching 110/220V AC mains [#21678039]
  • Request for IR sensor home appliance control idea
    #1 21678031
    Adnan Ali Saifi
  • #2 21678032
    Rick Curl
  • #3 21678033
    EEWeb
  • #4 21678034
    Adnan Ali Saifi
  • #5 21678035
    Adnan Ali Saifi
  • #6 21678036
    Rick Curl
  • #7 21678037
    Adnan Ali Saifi
  • IR receiver board uses a microcontroller and protocol decoding
    #8 21678038
    Rick Curl
  • Recommend using cheap RF mains switch modules
    #9 21678039
    David Ashton
  • Requesting a simple IR sensor relay circuit diagram
    #10 21678040
    Adnan Ali Saifi
  • Use pulsed IR and HT12E/HT12D for reliability
    #11 21678041
    David Ashton
  • #12 21678042
    Adnan Ali Saifi
The discussion focuses on designing a simple remote control system for home appliances such as bulbs and fans using an IR sensor and Arduino or basic electronic components. The user intends to use a common TV or AC remote as the IR transmitter without purchasing a dedicated IR remote. Key points include the complexity of decoding IR signals due to proprietary encoding protocols involving start bits, data streams, and checksums. A microcontroller or dedicated IC is typically required to interpret these signals. Suggested components for a basic circuit include an IR photodiode or IR receiver module, transistor, relay, and possibly encoder/decoder ICs like HT12E and HT12D for secure communication. The importance of using modulated IR signals (e.g., 5 kHz pulses) to avoid interference from ambient light is emphasized. Reference circuits and tutorials such as those on electronicshub.org were recommended for practical implementation. Safety concerns regarding switching mains voltage (110/220V AC) were also highlighted, advising caution. Alternative solutions like RF remote-controlled switch modules were mentioned but the user prefers a DIY IR-based approach for an academic project.
TL;DR: Expect “several hundred lines of code” and a microcontroller because consumer IR remotes use a “proprietary way of encoding.” Build it with an Arduino, an IR receiver, a driver transistor, and a relay to switch 110/220 V safely. [Elektroda, Rick Curl, post #21678038]
Why it matters: This FAQ shows students and hobbyists how to make a TV‑remote‑controlled mains switch safely and quickly, or pick a ready-made alternative.
What’s the exact goal this thread tackles?
Switch a 220 V light (and similar loads like a fan) on/off using an infrared sensor and a common TV/AC remote, built as a simple student project. [Elektroda, Adnan Ali Saifi, post #21678040]
Can I use a TV/AC remote directly with Arduino to toggle a relay?
Yes. Use an IR receiver module to decode the remote and have Arduino drive a transistor that energizes a relay. Remember, “each company…has their own proprietary way of encoding,” so you must decode and map buttons first. [Elektroda, Rick Curl, post #21678038]
Do I really need a microcontroller, or can I keep it all‑hardware?
You can skip protocol decoding by using an HT12E (encoder) at the transmitter and HT12D (decoder) at the receiver, then drive the relay. This simplifies logic but ties you to your own remote, not a TV remote. [Elektroda, David Ashton, post #21678041]
What IR modulation should I plan for in a simple build?
To reject ambient light, modulate your IR LED in bursts at a chosen frequency; an example student circuit used about 5 kHz. Remote controls use different schemes, so treat 5 kHz as a didactic example, not a universal setting. [Elektroda, David Ashton, post #21678041]
How do I stay safe when switching mains (110/220 V AC)?
Use a rated relay or SSR with proper creepage/clearance, an enclosed mains section, and strain relief. Keep low‑voltage and mains grounds isolated. If unsure, use a certified plug‑in module instead. Lethal voltages demand caution. [Elektroda, David Ashton, post #21678039]
Which Arduino library should I use to decode common TV remotes?
Use the IRremote library. It supports many protocols (NEC, Sony, Samsung, RC5/RC6, JVC, Panasonic, LG, and more), making button capture and mapping straightforward. [IRremote - Arduino Libraries]
Give me the 3 basic steps to build it with Arduino.
  1. Capture IR codes from your TV/AC remote using an IR receiver and the IRremote example to identify button values.
  2. Map chosen codes in your sketch to toggle a GPIO output state variable.
  3. Drive a transistor + flyback diode to energize a relay module that switches the lamp. [Understanding Sony IR remote codes, LIRC files, and the Arduino library]
What if sunlight or room lights cause false triggers?
Ambient IR can fool simple receivers. Use a modulated IR link and a demodulating receiver tuned to your burst frequency, add shielding, and position the sensor away from direct light. [Elektroda, David Ashton, post #21678041]
Is there a quick alternative if my deadline is near?
Yes. Buy a multi‑outlet RF remote kit. Around US$30 gets several plug‑in modules and a handheld remote that works through furniture and walls. [Elektroda, David Ashton, post #21678039]
What parts list should I start with for the student build?
Typical: Arduino (e.g., Nano/Uno), IR receiver module, IR LED (for learning/feedback), NPN transistor + base resistor, flyback diode, relay or SSR module, and a fused enclosure for mains wiring. [Elektroda, David Ashton, post #21678041]
What is Arduino Nano?
A compact, breadboard‑friendly Arduino board originally based on the ATmega328P (16 MHz, 32 KB flash). It offers Uno‑like functionality in a smaller form factor for embedded projects. [Arduino Nano]
What is Tuya?
Tuya (Tuya Smart) is a Chinese IoT platform‑as‑a‑service provider that powers many branded smart‑home devices and ecosystems worldwide. [Tuya Inc.]
What is CAN bus?
CAN bus is a differential, multi‑master serial network used in vehicles and industry, supporting robust, prioritized messaging up to 1 Mbit/s in Classical CAN. [CAN bus]
What is OpenBeken?
OpenBeken is open‑source firmware that replaces vendor firmware on Tuya‑type modules (e.g., BK7231), offering Tasmota‑like configuration, MQTT, and Home Assistant integration. [GitHub - openshwprojects/OpenBK7231T_App]
