Parts list for building a radio to receive 200 Hz–20 kHz audio signal range
417 19
How can I build a receiver to pick up a 200 Hz–20 kHz audio signal, and what parts do I need?
You can't pick a generic 200 Hz–20 kHz signal with an RF receiver until you know the actual carrier frequency and modulation, so the first step is to identify the transmitter details before choosing parts [#21668005][#21668007] One reply notes that a cochlear implant link may use a 1.8 MHz carrier with amplitude-coded digital modulation, which is not something you would listen to directly [#21668023] For an implant, magnetic coupling is suggested as a better approach than a normal RF antenna: use a coil on an amplifier, and on the receive side use a coil into a microphone-input style front end [#21668015] If you really are receiving a low-frequency/ULF signal, the posts suggest a loop or coil antenna rather than a simple length of wire, and on the receiver the input terminals go to the antenna while the output can drive an auxiliary speaker or recorder [#21668017][#21668020] If the signal is actually on a higher-frequency carrier, one suggested design is a band-pass filter around 455 kHz using standard AM IF cans, with bandwidth chosen for AM or SSB as needed [#21668014] The practical next step is to get the implant or transmitter specifications, or a circuit diagram, from the manufacturer or medical team before buying parts [#21668007][#21668017]
  • #1 21668004
    Alex Blanco
  • #2 21668005
    Steve Lawson
  • #3 21668006
    David Adams
  • Clarify whether the signal is audio or radio
    #4 21668007
    Frank Bushnell
  • Clarifying need for a receiver-only audio speaker setup
    #5 21668008
    Alex Blanco
  • #6 21668009
    Steve Lawson
  • Clarifying implant signal pickup and retransmission idea
    #8 21668011
    Frank Bushnell
  • Longwave radio needed instead of Bluetooth
    #9 21668012
    Alex Blanco
  • #10 21668013
    Frank Bushnell
  • 455 kHz IF band-pass filter recommendation
    #11 21668014
    Rodney Green
  • #12 21668015
    Ruben Proost
  • Questions about antenna, tuning, and I/O connections
    #13 21668016
    Alex Blanco
  • VLF antenna and untuned receiver guidance
    #14 21668017
    Frank Bushnell
  • #16 21668019
    Alex Blanco
  • Loop antenna likely needed for low-frequency reception
    #17 21668020
    Frank Bushnell
  • #18 21668021
    Alex Blanco
  • #19 21668022
    Frank Bushnell
  • Cochlear implant link uses 1.8 MHz carrier
    #20 21668023
    george gonzalez
The discussion centers on building a radio receiver capable of capturing audio signals in the 200 Hz to 20 kHz range, specifically related to a cochlear implant system transmitting wireless signals within this frequency band. Clarification was sought on whether the goal was to receive modulated RF signals carrying audio or directly receive audio frequency signals. The implant transmits longwave (ULF) radio frequencies rather than Bluetooth or typical AM/FM bands, with the medical team located remotely. Suggested components include a bandpass filter (potentially at 455 kHz IF for AM), operational amplifiers, coils or loop antennas for magnetic coupling, and active tunable notch filters for frequency selection. The use of a loop or coil antenna is recommended over simple wire antennas to avoid interference and improve selectivity. A referenced ULF radio project circuit was tested, with questions about antenna connection, tuning mechanisms, and input/output usage. It was noted that the implant’s carrier frequency might be in the MHz range with amplitude-coded digital modulation, implying the received signal may not be directly audible without demodulation. The importance of obtaining detailed transmitter specifications from the implant manufacturer or medical team was emphasized to design an appropriate receiver and antenna system.
TL;DR: For cochlear links, the external-to-implant hop often uses a 1.8 MHz carrier; “not anything that would be directly processable by the human ear.” Build around near‑field pickup and audio amplification, not a 20 Hz–20 kHz RF receiver. [Elektroda, george gonzalez, post #21668023]
Why it matters: If you design for audio‑band RF, you’ll miss the actual carrier and hear only noise. This FAQ helps hobbyists plan workable pickup, filtering, and amplification for implant-adjacent audio monitoring.
What does “receiving 200 Hz–20 kHz” actually mean for this project?
It refers to the desired audio band your speaker should reproduce, not an RF carrier in that band. Cochlear links commonly ride on a higher‑frequency carrier, so design for audio extraction after near‑field pickup, not for an RF receiver at 200 Hz–20 kHz. [Elektroda, george gonzalez, post #21668023]
Do cochlear implants transmit audio directly at audio frequencies?
No. An example shared used a 1.8 MHz carrier with amplitude‑coded digital control for the implant electrodes. That carrier powers and controls the implant; the raw RF is not directly listenable as sound. “Not anything that would be directly processable by the human ear.” [Elektroda, george gonzalez, post #21668023]
So how should I pick up the implant’s external signal?
Use a small loop or coil placed near the implant’s external coil to couple the magnetic field. Feed that into a low‑noise audio amplifier and then into a speaker or recorder. This near‑field approach minimizes unrelated broadcasts. [Elektroda, Ruben Proost, post #21668015]
Can I just use a long straight copper wire as the antenna?
A straight wire is not ideal here. For low frequencies and near‑field coupling, use a loop or coil across the two antenna terminals. Wire is cheap, so you can test loop sizes and turns to maximize pickup. [Elektroda, Frank Bushnell, post #21668020]
Where do I connect antenna and speaker on a simple ULF receiver board?
Connect the loop/coil to the input terminals marked for the aerial. Connect a speaker or attenuated line to the output terminals. This lets you monitor or record what the front end captures. “The input terminals connect to the aerial.” [Elektroda, Frank Bushnell, post #21668017]
Will an untuned ULF receiver isolate my implant’s signal?
No. Untuned front ends hear everything in their passband. Add selectivity after the pickup, such as a tunable notch or band‑pass filter, to suppress unwanted tones and hum while passing desired audio content. [Elektroda, Steve Lawson, post #21668018]
What is AFSK, and is it relevant here?
AFSK is Audio Frequency‑Shift Keying—digital data encoded as two audio tones. If your system used an RF carrier, AFSK could reduce acoustic interference. For pure near‑field audio monitoring, focus on magnetic pickup and audio amplification instead. [Elektroda, David Adams, post #21668006]
How wide should my filter be if I use an RF IF approach?
If you truly demodulate an RF carrier, speech‑grade AM needs about 10 kHz audio, while wider hi‑fi needs more. One suggestion used 455 kHz IF cans and noted SSB is easier to filter narrowly. Match bandwidth to your content. [Elektroda, Rodney Green, post #21668014]
Can I tune specific frequencies on the Stormwise‑style ULF project?
That project is broadband. Add an active tunable notch or band‑pass stage after the preamp to target a particular tone region. Insert it between the detector and audio amp to shape what reaches the speaker. [Elektroda, Steve Lawson, post #21668018]
Is the 20 kHz upper limit useful for everyone?
Not always. One contributor noted few adults can hear 20 kHz. Designing for 15–18 kHz often delivers similar perceived quality while easing filter and amplifier demands. That tradeoff can simplify your build. [Elektroda, Frank Bushnell, post #21668007]
Any risk of picking up unrelated radio stations or hum?
Yes. Far‑field RF and mains hum can leak in. “Use a magnetic coupling rather than RF to avoid picking up radio stations all day.” Keep loops small, shield the preamp, and use notch filtering for 50/60 Hz. [Elektroda, Ruben Proost, post #21668015]
How do I physically try a coil pickup quickly? (3‑step)
  1. Wind 20–50 turns of enamel wire on a 3–5 cm former.
  2. Connect the coil across the receiver’s antenna input.
  3. Place it near the external implant coil and adjust distance/angle for strongest audio. [Elektroda, Frank Bushnell, post #21668020]
Who can confirm the exact carrier and protocol for my implant?
Ask your implant manufacturer or clinical team for the link specs and approved accessories. They use test receivers and coils and may share a compatible monitoring schematic or antenna details. This saves guesswork. [Elektroda, Frank Bushnell, post #21668020]
Does the chosen Stormwise ULF receiver fit this goal?
It can amplify very low‑frequency fields, but your implant may use a higher RF carrier for power and data. Without matching the actual link method, results may be weak or noisy. Verify the link before investing more. [Elektroda, Alex Blanco, post #21668016]
Can I route the receiver output to a recorder instead of a speaker?
Yes. Use the output terminals and add attenuation if needed to meet line‑level. This helps capture sessions for later analysis or adjustment while avoiding clipping. [Elektroda, Frank Bushnell, post #21668017]
