How does an oscillator circuit using op-amp and zener diode generate stable frequency?
237 6
  • #1 21668106
    joko Ivanovic
  • #2 21668107
    David Adams
  • #3 21668108
    Rohit Dubla
  • #5 21668110
    Rohit Dubla
  • #6 21668111
    Steve Lawson
  • #7 21668112
    Rohit Dubla
An oscillator circuit using an op-amp and a zener diode generates a stable frequency by producing a pulsed output waveform, typically a square or trapezoidal wave rather than a pure sinusoid. The circuit functions similarly to a Schmitt trigger oscillator, where resistors and a capacitor set the timing characteristics. The zener diode limits the output amplitude, clipping the waveform peaks to maintain a consistent voltage range, often between 0 to 3V. The output waveform can be observed as a rectangular wave at the op-amp output and a sawtooth-like waveform at an intermediate node, shaped by the charging and discharging of the capacitor through resistors. Although the waveform is not a true sawtooth or triangle wave due to its exponential charge/discharge profile, it is sufficient for applications where precise linear slopes are not critical. Simulation tools like CircuitLab can be used to analyze and verify the waveform behavior and frequency stability.
