Best Filter Type to Remove DC Offset in Biomedical Signals (0-20Hz) After IA
282 6
  • High-pass filtering to remove IA dc offset
    #1 21668146
    Shaik Shabana
  • #2 21668147
    Rodney Green
  • #3 21668148
    Kevin Parmenter
  • Digitize output and cancel DC in firmware
    #4 21668149
    Rohit Dubla
  • #5 21668150
    Steve Lawson
  • Chopper-stabilized op-amps for microvolt dc stability
    #6 21668151
    Rodney Green
  • #7 21668152
    Kevin Parmenter
In biomedical signal acquisition with instrumentation amplifiers (IA), DC offset at the IA output is a common issue. Since biomedical signals of interest range from 0 to 20 Hz, filtering out DC using high-pass or band-pass filters can remove important low-frequency components, making such filters generally unsuitable. Instead, offset suppression methods include using a stable level shifting circuit with an operational amplifier to null the DC offset, or implementing an active offset nulling scheme with integrator-based feedback to compensate for DC at the IA output. Manual trimming is possible but unreliable due to environmental variations. Digitizing the IA output directly and correcting DC offset in firmware or software is recommended for better reliability. Chopper-stabilized operational amplifiers can offer very low DC offset (in microvolts) and improve stability. Suggested op-amps for offset reduction include OP07 and AD707, which have low input bias currents and good DC characteristics. When disconnecting the sensor for offset calibration, substituting an impedance similar to the sensor’s is advised to maintain circuit conditions.
