Following IPC Standards vs Manufacturer Specs for IC Pad Footprints and Pitch
252 9
Should I follow IPC recommendations or the IC manufacturer's footprint specifications when designing pads and pitch for an IC?
For production boards, follow the manufacturer’s footprint specifications; they are intended to minimize stress on the part during reflow, while the pad spacing must still match the component’s lead pitch so the pins line up [#21668568] For prototyping and hand soldering, it is common to make pads larger for easier assembly [#21668567][#21668568] If the part dissipates heat, you may also need a larger pad or a connection to a copper pour, and manufacturers may recommend that for power devices instead of the plain IPC pad style [#21668571] Some contract manufacturers also prefer larger pads on small SMD parts so enough solder paste is deposited when using a stencil [#21668571]
  • #1 21668566
    Emmanuel Galleto
  • #2 21668567
    stephen Van Buskirk
  • #3 21668568
    Steve Lawson
  • #4 21668569
    Emmanuel Galleto
  • #5 21668570
    Emmanuel Galleto
  • Larger pads recommended for hot power devices
    #6 21668571
    stephen Van Buskirk
  • #7 21668572
    Rogerio Regel
  • #8 21668573
    Emmanuel Galleto
  • #9 21668574
    Emmanuel Galleto
  • #10 21668575
    Nick Ban
When designing IC pad footprints, prototyping often involves customizing pad sizes larger than IPC standards to facilitate hand soldering and improve heat dissipation, especially for power devices like MOSFETs. For production, it is advisable to follow manufacturer specifications, which are optimized for reflow soldering and mechanical stress reduction. Pad pitch must always match the component lead pitch to ensure proper alignment. Manufacturers may recommend larger copper pads or direct connections for heat-generating components rather than relying solely on IPC standard pads. Contract manufacturers sometimes prefer larger pads on small surface-mount transistors to ensure adequate solder paste application with stencils. For hobbyist or compact designs, such as Arduino-sized PCBs, balancing pad size and board space is a consideration. Tools like PCB Libraries and the Library Expert software can assist in creating accurate footprints and 3D STEP models.
