How to Calculate Inductance of 12V Relay Coil Using Only Coil Resistance Value?
954 8
  • #1 21668595
    abhijeet Sathe
  • Coil inductance must be measured or calculated from geometry
    #2 21668596
    Frank Bushnell
  • Measuring relay coil inductance with an oscilloscope
    #3 21668597
    DAVID CUTHBERT
  • Relay coil unsuitable for AM tuning; wind 100-turn air-core inductor
    #5 21668599
    Rodney Green
  • #6 21668600
    Mark Harrington
  • #7 21668601
    abhijeet Sathe
  • #8 21668602
    Santosh A
  • #9 21668603
    Rohit Dubla
The inductance of a 12V relay coil cannot be directly calculated from its coil resistance alone, as resistance does not provide sufficient information about inductance. To determine the inductance, one can use an LCR meter or an inductance meter for direct measurement. Alternatively, an experimental method involves applying a voltage to the coil through a current-sensing resistor (with resistance less than one-tenth of the coil resistance) and measuring the time it takes for the current to reach 63% of its final value using an oscilloscope. Using the time constant formula T = L/R, where T is the measured time and R is the coil resistance, the inductance L can be calculated as L = T × R. This inductance value is important for understanding relay drop-out times, stored energy, and flyback voltage characteristics. Additional references include online coil inductance calculators and DIY inductance meter projects based on 555 timers. It is also noted that relay coils with iron cores have magnetic properties and self-capacitance that affect their behavior at radio frequencies, making them unsuitable for high-frequency applications without modification.
