Why Does Hair Stand Up When Touching a Van de Graaf Generator? Electrostatic Effect
501 12
Why does a person's hair stand straight up when they touch a Van de Graaff generator?
Their body becomes charged by the Van de Graaff generator, and if they are well insulated from ground the charge builds up on them [#21668689][#21668690] Because each hair strand ends up with the same polarity, like charges repel and the strands push away from one another [#21668690] That repulsion makes the hair spread out and stand on end, since the strands are tethered to the scalp but still free to move [#21668690] This is an electrostatic force strong enough to lift hair, but not strong enough to lift larger body parts [#21668690]
  • #1 21668688
    Franklin Rey Pacquiao
  • #2 21668689
    Steve Spence
  • Like charges repel, making hair stand up
    #3 21668690
    Steve Lawson
  • #4 21668691
  • DIY Van de Graaff generator build links and belt sources
    #5 21668692
    Mark Harrington
  • Restoring a Technics amp with LED display mod
    #6 21668693
    Mark Harrington
  • Serviced an Akai unit without schematics
    #7 21668694
    Mark Harrington
  • #8 21668695
    Mark Harrington
  • #9 21668696
    Steve Lawson
  • #10 21668697
    Steve Lawson
  • #11 21668698
    Mark Harrington
  • Venue safety concerns and ignored engineering warnings
    #12 21668699
    Mark Harrington
  • Unsafe, poorly planned venue layout criticized
    #13 21668700
    Mark Harrington
The phenomenon of hair standing up when touching a Van de Graaff generator is caused by the accumulation of electrical charge on the person. The generator builds up a high voltage on its dome by either adding or removing electrons, creating a strong electrostatic field. When a person touches the dome, the charge transfers to their body and hair strands, which all acquire the same polarity. Due to the principle that like charges repel, each hair strand repels adjacent strands, causing the hairs to stand on end to maximize distance from each other. The discussion also includes practical advice on constructing simple Van de Graaff generators using common materials like metalized bowls and coke cans, with cautions about material choices such as avoiding aluminum due to its reactive properties. Additional unrelated posts mention servicing audio equipment from brands like Technics Panasonic and Akai, highlighting the decline of skilled tradespeople and the importance of preserving technical knowledge.
TL;DR: A Van de Graaff demo unit can store about 300,000 V; "The electrons repel each other," so each hair strand pushes away and stands up. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
Why it matters: This FAQ helps students, hobbyists, and teachers run safe, impressive static‑electricity demos and troubleshoot weak hair‑raising effects.
  • Typical classroom generators: Approx. 300 kV potential; humidity reduces performance. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
  • Principle: Like charges repel; opposite charges attract (Coulomb’s law). “Coulomb’s law | Britannica”
  • Safety: Stand on an insulating stool or mat to avoid shock paths to ground. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
  • DIY tip: Replacement belts and build ideas are available; hobbyists often upcycle parts. [Elektroda, Mark Harrington, post #21668692]
What makes hair stand up when I touch a Van de Graaff generator?
Charge flows to you from the dome and spreads over your body. Each hair picks up the same polarity. Like charges repel, so strands push apart and rise until forces balance gravity and stiffness. “Coulomb’s law | Britannica”
Do I need to be insulated from ground for the hair‑raising to work?
Yes. If you touch ground, charge leaks away and the effect collapses. Insulate yourself with dry shoes or a plastic stool, then touch the dome for best results. [Elektroda, Steve Lawson, post #21668690]
Why doesn’t the generator lift my arms too?
Electrostatic force from the demo is strong enough for light hairs, not heavy limbs. Hair rises because it has low mass and flexible roots. "The force is strong enough to lift strands of hair, but not human limbs." [Elektroda, Steve Lawson, post #21668690]
How many volts does a typical unit produce?
Classroom systems often reach around 300,000 volts. Large research machines have achieved multi‑megavolt potentials for accelerators. That high voltage is low current in demos, emphasizing spectacle over power. “Robert Jemison Van de Graaff | Britannica”
Why does humidity ruin the hair‑raising effect?
Moist air conducts charge away along damp surfaces. Leakage prevents charge buildup on your body and hair, so little or no lift appears. Run demos on dry days for best results. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
Is a Van de Graaff generator safe to touch?
With proper insulation and supervision, classroom demos are safe. Avoid pacemakers, sensitive electronics, and direct paths to ground. Discharge the dome with a grounded wand after use. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
What is a Van de Graaff generator?
It is an electrostatic machine that transports charge on a moving insulating belt into a hollow metal dome. The dome’s potential rises until leakage or discharge limits it. “Robert Jemison Van de Graaff | Britannica”
What is electrostatic force, in simple terms?
Electrostatic force is the push or pull between electric charges at rest. Like charges repel and unlike charges attract, as quantified by Coulomb’s law. “Coulomb’s law | Britannica”
How do I run a reliable hair‑raising demo?
  1. Dry the room and insulate the volunteer from ground.
  2. Start the generator, then have the volunteer place one hand on the dome.
  3. Keep the other hand away from grounded objects; wait 5–15 seconds for hair to rise. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
Why did my hair not stand up at all?
Common failures include high humidity, touching ground inadvertently, or long, oily, or wet hair providing leakage paths. Isolate, dry, and try again with clean, dry hair. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
Can I build a simple Van de Graaff at home?
Yes. Makers repurpose rollers, motors, and domes, and source belts from specialty suppliers. Community posts share plans and parts links for hobby‑scale builds. [Elektroda, Mark Harrington, post #21668692]
What can I use for the dome, and what should I avoid?
Hobbyists often form domes from two metal bowls, joining and smoothing the seam. One poster warns against aluminum for thermal reasons and suggests silver solder. Follow qualified guidance if attempting builds. [Elektroda, Mark Harrington, post #21668695]
Does the generator always charge the dome negatively?
No. Depending on belt and roller materials, the dome can accumulate either polarity. The effect on hair is the same because strands share the same sign and repel. “Coulomb’s law | Britannica”
What’s an edge case where sparks jump instead of hair rising?
If a grounded object approaches, the field may exceed air’s breakdown strength. A visible spark discharges the dome and your hair falls immediately. “Our Van de Graaff Hall of Fame! – The Wonders of Physics – UW–Madison”
What voltage have the largest machines reached?
Well‑engineered, enclosed machines have produced about 13 megavolts for particle acceleration. These systems are far larger than classroom models. “Robert Jemison Van de Graaff | Britannica”
