How to confirm current rating of unlabelled MCBs bought without stickers?
348 18
How can I safely confirm the current rating of an unlabelled AC miniature circuit breaker?
Use a proper primary injection test set to ramp current through the breaker until it trips; for a single-pole AC breaker up to 63 A, a 0–100 A injector was suggested as sufficient [#21669004][#21669006][#21669009] Do not try to verify an AC breaker with a DC bench supply, and do not build your own test rig unless you are qualified, because safety and liability issues were raised [#21669006][#21669007] If you only need an approximate range, one suggestion was to put the unknown breaker in series with breakers of known ratings and see which one trips first, then narrow it down step by step [#21669020] Lamp-based loads were discussed, but they were noted as unreliable because filament resistance changes with temperature [#21669017]
  • #1 21669002
    Malik Maqbool Jumani
  • Use a bench supply to trip the breaker
    #2 21669003
    Steve Lawson
  • Current injection test to determine breaker rating
    #4 21669005
  • Safety warning against DIY MCB current testing
    #5 21669006
    Mark Harrington
  • #6 21669007
    Steve Lawson
  • #7 21669008
    Steve Lawson
  • #9 21669010
    Mark Harrington
  • Current injection kits for testing 63 A breakers
    #10 21669011
  • #11 21669012
    Steve Lawson
  • #12 21669013
    Mark Harrington
  • #13 21669014
    Steve Lawson
  • #14 21669015
    Mark Harrington
  • Parallel lamp test is unsafe for breaker rating confirmation
    #15 21669016
  • Filament lamp is an unreliable test load
    #16 21669017
    Steve Lawson
  • #17 21669018
  • #18 21669019
    Steve Lawson
  • Using known breakers to bracket an unknown rating
    #19 21669020
    Steve Lawson
The discussion addresses methods to determine the current rating of unlabelled miniature circuit breakers (MCBs) purchased without stickers. One proposed method involves using a DC bench power supply with adjustable current to gradually increase current until the breaker trips, identifying its rating. However, this approach is cautioned against due to differences between AC and DC breakers and safety regulations. Instead, specialized primary injection test kits, such as those from Megger and TR Test, are recommended for accurate and safe testing of single-pole AC breakers up to 63 amps. Alternative low-cost methods include using parallel-connected incandescent lamps as a load to incrementally increase current until the breaker trips, though this is less reliable due to the non-linear resistance of filament lamps and potential limitations of the mains supply. Another suggested technique is to use breakers of known ratings in series with the unknown breaker to bracket its trip current range. Safety concerns and legal liabilities are emphasized, advising against DIY testing without proper qualifications and equipment.
TL;DR: To identify an unlabelled MCB’s current rating, avoid DIY high‑current tricks; most outlets are 15–20 A and “most of our outlets are protected by 15, or 20 Amp breakers.” Use a primary injection tester or bracket with known breakers. [Elektroda, Steve Lawson, post #21669017]
Why it matters: Correctly confirming an MCB’s rating prevents nuisance trips, overheated wiring, and dangerous fault-testing setups for DIYers and technicians.
What’s the safest way to confirm an unlabelled MCB’s current rating?
Use a certified primary injection tester or have a test house do it. Avoid home‑built high‑current rigs. Safety regulations and liability apply when equipment faults under test. Buying or renting approved gear protects you and clients. “Go and Buy one!!” remains sound advice for non‑specialists. [Elektroda, Mark Harrington, post #21669006]
Can I use a bench DC power supply to test an AC MCB?
No. AC and DC breakers behave differently, and a bench supply is not appropriate for high‑current AC trip testing. As one expert put it, “testing this DC wise is a No.” Use purpose‑built injection equipment instead. [Elektroda, Mark Harrington, post #21669006]
Is using parallel incandescent lamps a reliable test load?
Not reliably. Filament resistance rises sharply as the lamp heats, so current doesn’t scale linearly. That makes trip points inaccurate, especially as you add lamps. It’s risky to assume exact amperage from nameplate watts alone. Use calibrated methods or measure current at the instant of trip. [Elektroda, Steve Lawson, post #21669017]
How can I estimate the rating without special gear?
Bracket with known breakers. Put a known‑value breaker in series with your unknown device under test. Increase load until one trips. If the known trips first, the unknown’s rating is higher; step up until the unknown trips to find its range. This gives a practical ballpark value. [Elektroda, Steve Lawson, post #21669020]
How do I run a quick low-cost test with lamps and measurements?
Try a measured approach:
  1. Build a lamp load and monitor line voltage continuously.
  2. Measure instantaneous current at trip with a meter or data logger.
  3. Use a variac to match single‑lamp voltage to multi‑lamp voltage and extrapolate per‑lamp current. This improves accuracy versus watts-only assumptions. [Elektroda, Steve Lawson, post #21669020]
How much current can my supply realistically deliver for testing?
Many outlets are on 15–20 A breakers; larger appliances use 30–40 A. Your service transformer and upstream protection may limit available current. Trying to draw 30+ A from a standard receptacle can trip supply breakers or cause voltage sag. Confirm your upstream ratings before any test. [Elektroda, Steve Lawson, post #21669017]
Will adding more lamps give a linear current increase?
No. As parallel lamps heat, resistance changes and the mains voltage can droop. Both effects skew current. Calibrate by matching the measured voltage across a single lamp (via variac) to the multi‑lamp voltage, then multiply the single‑lamp current by lamp count. Verify per‑lamp consistency. [Elektroda, Steve Lawson, post #21669020]
Which tool suits single‑pole AC breakers up to 63 A?
Use a portable primary injection tester from a reputable brand such as Megger. Choose a model covering at least 0–100 A for margin and with adequate duty cycle. New users should prioritize safety interlocks and clear trip‑time readout. Rental may be cost‑effective for occasional tests. [Elektroda, Mark Harrington, post #21669004]
Can I test directly on 230 V mains if my main breaker is 63 A?
You can only test within the limits of your supply. One user confirmed a 63 A main but planned tests to 32 A. Even then, ensure wiring, outlets, and upstream protection tolerate the load. Oversights here risk nuisance trips or hazards. Plan conservatively. [Elektroda, Malik Maqbool Jumani, post #21669018]
What should I actually measure during a trip test?
Capture the instantaneous current at the moment the breaker opens. A clamp meter with peak capture or a data logger helps. Voltage should be monitored too, as sag affects current. Accurate trip current matters more than assumed load size. “It’s a matter of knowing the current at the moment.” [Elektroda, Steve Lawson, post #21669019]
Do I need to check each lamp’s current if I use them as a load?
Yes. Measure current through each lamp at the same applied voltage, since manufacturing variance and heating change resistance. The variac-plus-single‑lamp method lets you derive per‑lamp current, then scale by lamp count for the total. This reduces error in your trip estimate. [Elektroda, Steve Lawson, post #21669020]
What if my available supply is only 10 A or 15 A?
You won’t reach 32 A or higher with that supply. You’ll trip upstream protection first or see severe voltage drop. For higher ratings, use an industrial supply point or a primary injection tester that sources the required current safely. Avoid overstressing circuits. [Elektroda, Steve Lawson, post #21669017]
