How to Build a Linear Voltage Decay Circuit (9V-12V DC, 3-5s Ramp Down)
402 17
How can I build a simple circuit that takes a 9–12 V DC input and makes the output fall linearly from full voltage to about 0 V over 3–5 seconds, then return instantly to full voltage when power is reapplied?
Use a capacitor charged by a constant-current source so the voltage changes linearly, and take the output from the collector side so it ramps down from Vcc to 0 V while the capacitor voltage rises [#21669117] The suggested implementation uses a transistor, LED and emitter resistor to make a constant current source; as the capacitor charges, the output falls linearly, and if the capacitor starts discharged when power is applied the output is immediately at full battery voltage again [#21669117] The ramp slope is given as V(t)=I·t/C, so for a 3-second fall from 10 V with 1 mA current you’d need about 300 µF [#21669121] A later simulation of the corrected circuit showed about 5.5 s with R1=10 kΩ and about 3 s with R1=560 Ω, and noted that R1 affects timing more than linearity [#21669129] If exact timing matters, the reply suggests making R1 itself a current source for better accuracy [#21669129] An optional resistor R3 can set the lowest output level, but it is not needed if you want the output to go all the way to 0 V [#21669117]
  • Request for a 3–5 second linear voltage decay circuit
    #1 21669115
    Andrew Betts
  • #2 21669116
    Rohit Dubla
  • Current-source capacitor ramp for linear voltage decay
    #3 21669117
    Rohit Dubla
  • #4 21669118
    Andrew Betts
  • #5 21669119
    Andrew Betts
  • #6 21669120
    Steve Lawson
  • Linear ramp calculation from constant-current discharge
    #7 21669121
    Rohit Dubla
  • #8 21669122
    Andrew Betts
  • PWM ramp control with 555 timer or microcontroller
    #9 21669123
    Mark Harrington
  • #10 21669124
    Rohit Dubla
  • Constant-current discharge circuit for linear ramp down
    #11 21669125
    Steve Lawson
  • #12 21669126
    Steve Lawson
  • #13 21669127
    Mark Harrington
  • PWM light dimmer with memory and step display
    #14 21669128
    Mark Harrington
  • R1 affects ramp-down time, not linearity
    #15 21669129
    Rohit Dubla
  • #16 21669130
    Rohit Dubla
  • #17 21669131
    Steve Lawson
  • #18 21669132
    Rohit Dubla
The discussion focuses on designing a linear voltage decay circuit that, when powered with 9V to 12V DC, produces a linear ramp-down output voltage from the supply voltage to near 0V over 3 to 5 seconds. The user requires the output to remain at the supply voltage while powered and then linearly decay to zero upon power removal, with the process repeating upon reapplication of power. A 555 timer-based ramp generator was found but operates in the opposite direction (0V to 12V). Proposed solutions include using a constant current source (CCS) to linearly charge a capacitor, thereby creating a linear voltage ramp across the capacitor, which is subtracted from the supply voltage to achieve the desired linear decay at the output. The slope of the ramp is governed by the current and capacitance (V(t) = (I*t)/C), allowing calculation of component values for the desired timing. Alternative approaches suggest using PWM control via a 555 timer or microcontroller (Atmel or PIC) with low-pass filtering to achieve adjustable linear voltage decay. Circuit simulations indicate that adjusting resistor values in the CCS affects ramp time but not linearity. Some shared circuits use transistor, LED, and resistor configurations to implement the CCS, with attention to voltage references and capacitor types (ceramic or tantalum) for precision. The output voltage is intended to feed into a 555 timer control pin (pin 5) to modulate its output. The discussion also notes the importance of ensuring the output voltage instantly returns to supply voltage when power is reapplied and that the voltage decay is linear rather than exponential or logarithmic.
TL;DR: For a 12→0 V linear ramp in 3–5 s, use a constant‑current source into a capacitor; 300 µF at 1 mA ≈ 3 s. “The CCS will ensure that the ramp is linear.” [Elektroda, Rohit Dubla, post #21669121]
Why it matters: This FAQ shows how to build and tune a simple, repeatable linear voltage decay for hobby and embedded projects, without microcontrollers.
Quick-Facts
How do I get a 12 V to ~0 V linear ramp after power turns on?
Use a constant‑current source (LED + transistor + R1) to charge a capacitor. Subtract the capacitor’s rising voltage from Vcc at the collector to get a linear falling output. Adjust R1 (current) and C (capacitance) to set duration. [Elektroda, Rohit Dubla, post #21669117]
What values give about 3 seconds over a 10 V span?
Use V(t)=I·t/C. For a 3 s drop from 10 V, pick C=3·I/Vcc. Example: I=1 mA, Vcc=10 V → C≈300 µF. “V(t)=(I·t)/C.” [Elektroda, Rohit Dubla, post #21669121]
Will the output jump back to 12 V when power returns?
Yes. The requirement is immediate return to 12 V on re‑apply. Design the ramp to occur only during powered intervals. [Elektroda, Andrew Betts, post #21669119]
I only have an upward ramp—how do I get a downward ramp for PWM/comparator use?
Swap the comparator inputs: use the ramp on one input and the reference on the other to invert the slope. [Elektroda, Rohit Dubla, post #21669124]
Does the ramp have to drive a heavy load?
Assume a light load. If you must drive more than a control pin, buffer the output. The discussion assumes minimal loading. [Elektroda, Steve Lawson, post #21669120]
How do I tune the time without hurting linearity?
Change R1 to set current and C to set duration. Simulation showed R1=10 kΩ ≈5.5 s and 560 Ω ≈3 s, with linearity maintained. [Elektroda, Rohit Dubla, post #21669129]
What is a constant current source (CCS) here?
A transistor with LED and emitter resistor forms a CCS. It forces near‑constant current, making the capacitor voltage rise linearly. “The CCS…will ensure that the ramp is linear.” [Elektroda, Rohit Dubla, post #21669121]
Will this ramp continue after power is removed?
This thread’s solution targets a ramp during power‑on. A post clarified that a post‑power‑off ramp was a misread requirement. [Elektroda, Steve Lawson, post #21669131]
Any pitfalls or edge cases I should know?
Diode‑referenced current sources drift with temperature. Expect timing variance unless you stabilize or calibrate the reference network. [Elektroda, Steve Lawson, post #21669125]
