Designing a 555 Timer Circuit for 3-Minute SCR-Controlled 12VDC Load Under 1A
300 11
How can I design a 3-minute delay circuit that, after power-up, triggers a switch for a 12 VDC load under 1 A and then stays on until power is removed?
Use a CMOS timer/oscillator such as the CD4060 or MC14060B with a p-channel MOSFET high-side switch instead of an SCR, and tweak the timing components (R2 and/or C1) to get the 3-minute interval [#21670594] Make sure the CMOS part can tolerate the rectified 6.3 VAC supply, which is about 8.1 V after rectification, so a 74HC4060 is too low-rated while the MC14060B (18 V max) is suitable [#21670594] The MOSFET will have very little voltage drop at 1 A, unlike an SCR which may drop around 1 V, so if you need that drop you would have to add series rectifiers [#21670594] R7 with C3 provides power-on reset, R8 discharges the capacitors after power-off, and D2 prevents the 12 V path through R5 from affecting the oscillator until Q2 turns on [#21670596] For parts, Steve cited examples such as the IRF9Z34PBF MOSFET and the CD4060BE, and noted that the circuit can also be fed from the 12 V supply to reduce parts count [#21670596]
  • #1 21670587
    Harbach Electronics LLC
  • Clarifying load, unit, and delay-tube behavior
    #2 21670588
    Steve Lawson
  • 3-minute power-up delay for SCR switch-on
    #3 21670589
  • #4 21670590
    Steve Lawson
  • #5 21670591
    Steve Lawson
  • #6 21670592
    Steve Lawson
  • #7 21670593
    Steve Lawson
  • Adjust R2/C1 and use higher-voltage CMOS part
    #8 21670594
    Steve Lawson
  • #9 21670595
  • Power-on reset, discharge, and supply-current questions
    #10 21670596
    Steve Lawson
  • P-channel MOSFET criteria and 4060 package warning
    #11 21670597
    Steve Lawson
  • #12 21670598
The discussion centers on designing a 555 timer-based delay circuit to replace an Amperite time delay tube. The goal is a 3-minute timer powered from a rectified 6.3 VAC tube filament supply, which after timing triggers an SCR or transistor switch to supply a 12 VDC load under 1A continuously until power is removed. Clarifications established that the timer starts on unit power-up, counts 3 minutes, then activates the SCR to latch the 12 VDC load on. Various schematic suggestions were provided, including using a CD4060 CMOS oscillator/timer IC for timing instead of a 555, due to voltage and timing stability considerations. The use of a p-channel MOSFET (e.g., IRF9Z34) as a low-drop switch alternative to an SCR was recommended to reduce voltage drop and power dissipation. Components such as resistors for current limiting and timing adjustment, diodes for blocking unwanted current paths, and power-on reset circuits were discussed. The importance of selecting CMOS parts with appropriate voltage ratings (e.g., ON Semi MC14060B with 18V max VDD) was emphasized. Suggestions included considering a microcontroller (e.g., PIC12HV609) and high-side MOSFET switches (e.g., BTS4175SGA) for production designs. Availability and packaging of components, PCB design, and production considerations were also addressed.
TL;DR: From 6.3 VAC, expect ~8.1 VDC after rectification; “use a CMOS part that has a max voltage higher than the VDD supply.” [Elektroda, Steve Lawson, post #21670594]
Why it matters: This FAQ shows how to build a reliable 3‑minute, high‑side‑switch timer for a 12 VDC load under 1 A, replacing an Amperite tube, with parts you can still source.
Why use a P‑channel MOSFET instead of an SCR here?
A P‑channel MOSFET used as a high‑side switch has near‑zero drop at 1 A, while an SCR drops about 1 V when conducting. [Elektroda, Steve Lawson, post #21670594]
Which timer/counter IC fits this supply and what are safe limits?
Use a CMOS 4060 variant with headroom above VDD. 74HC4060 maxes at 7 V; MC14060B tolerates up to 18 V. [Elektroda, Steve Lawson, post #21670594]
How do I set a 3‑minute delay with the 4060 oscillator?
Tweak the RC. 1) Start with R2 and C1 that land near 180 seconds. 2) Adjust R2 to fine‑tune frequency. 3) Change C1 if coarse shift is needed. [Elektroda, Steve Lawson, post #21670594]
Can I power the timer from the 12 VDC rail instead of 6.3 VAC?
Yes. A variation uses the 12 VDC supply directly, reducing parts versus rectifying and filtering the 6.3 VAC source. [Elektroda, Steve Lawson, post #21670596]
Any lifecycle or package concerns for the 4060 family?
Yes. PDIP 4060 parts were near end‑of‑life; consider SOIC packages and adapter boards for production builds. [Elektroda, Steve Lawson, post #21670597]
What MOSFET specs should I target for a 12 V, <1 A load?
Choose P‑channel, RDS(on) ≈100–200 mΩ, VGS(max) >12 V, VDS(max) >24 V, and >0.5 W dissipation. “Hundreds… of other possibilities.” [Elektroda, Steve Lawson, post #21670597]
What happens if I omit the discharge resistor on the timing capacitors?
Without R8, the capacitors may not discharge after power‑off, causing incorrect timing on the next start. [Elektroda, Steve Lawson, post #21670596]
