We are using the At32UC3A3 controller and LTC2941 IC for the Li-Ion battery level monitoring. Our project's main objective is to create a USB-based device that will indicate the battery levels using LED blinking and LTC2941 IC. Now I made the LTC Configuration successfully with the AT32UC3a3 controller. My question is how can I make the code for the battery level measurement using the LTC2941 that will indicate whether it is charging or discharging. Please help me clarify...
Diagram
Clarifying LTC2941 battery level and charge state code
We are use the At32UC3A3 controller and LTC2941 IC for the Li-Iom battery level monitoring. our project main motto a usb based device so we need to indicate the battery levels using LED blinking and LTC2941 IC. Now i made the LTC Configuration Successfully with theAT32UC3A3 controller. Now how can i made the code for the battery level measuring using the LTC2941 when charging and discharging states. Please clarify as earlier
Design criticized as overcomplicated and overdesigned
What a waste of a processor why such a large processor to do one single job ?
Why didn’t use the LC2942-1A with integral sense resistor ?
You must have copied the diagram did you do the design yourself?
If you didn’t do the diagram yourself why did you use this processor it seems vastly over designed to achieve your final aims and also if you knew how to put this together hardware wise forgive me for asking but why are you asking us to give the code to do this Surely if you knowledge is this extensive you would know how to do this Its only I2C protocol Its Not that difficult why the DC to DC converters Why didn’t you use a smaller device with USB interface chip instead
Its overly complicated for what you want to achieve No wonder your asking for someone to write the code for you
What do you expect to learn from this by us writing code for you ?? Its a good question isnt it what do you expect to gain from this ?
I think you should go back to the drawing bourd myself and think though your design and your work and what you expect to learn from this
Hi., Thank for you prompt reply. Our controller works with some other Peripherals.But still LTC2941 based battery level monitoring part of the Project only my consideration. Hence now i configure and establish the TWI communication between the LTC2941 and AT32UC3A3. Now what are the steps to write a code for the LTC2941 based battery level measuring. Please suggest to me...
Go and take a course in C programming inclusive micro's and sit many moons, many years many summers , many nights in , suffering , puling hair out , not enjoying ourselves , not spending money except on investments indoors teaching yourself like weve had too
