How to Calculate Voltage Drop Across Two Series Resistors in a Circuit?
330 16
How do I find the separate voltage drops across two resistors in a circuit that also includes a current source?
Because the circuit includes a current source, the two resistor drops are not equal; for the shown circuit, the correct drops are 0.5 V across Rab and 1.5 V across Rbc [#21670081] [#21670083] The corrected branch-current relation is Ibc = Iab + 1 A, not Iab - 1 A [#21670081] Using KVL with the 2 V source and 1 Ω resistors gives 2 = Iab(1) + (Iab + 1)(1), so Iab = 0.5 A [#21670081] Then Vab = 0.5 V and Vbc = 2 V - 0.5 V = 1.5 V [#21670081] The Norton-equivalent explanation also confirms that the original circuit’s Rab is 0.5 V, not 1.5 V [#21670083] [#21670084]
  • #1 21670071
    ASAD ALI
  • #2 21670072
    Sajed Rakhshani
  • Kirchhoff analysis gives 1 V across each resistor
    #3 21670073
    Steve Lawson
  • Corrected current calculation gives 1.5 V and 0.5 V drops
    #4 21670074
    Steve Lawson
  • #5 21670075
    DAVID CUTHBERT
  • Kirchhoff laws show 1.5 V across both resistors is impossible
    #6 21670076
    Steve Lawson
  • #7 21670077
    ASAD ALI
  • #8 21670078
    Steve Lawson
  • #9 21670079
    ASAD ALI
  • #10 21670080
    Sajed Rakhshani
  • Correcting current split gives 0.5 V across Rab
    #11 21670081
    Steve Lawson
  • #12 21670082
    Steve Lawson
  • #13 21670083
    Sajed Rakhshani
  • #14 21670084
    Steve Lawson
  • #15 21670085
    Cody Gass
  • Voltage divider analysis with current source removed
    #16 21670086
    Cody Gass
  • #17 21670087
    Cody Gass
The discussion addresses calculating voltage drops across two series resistors in a circuit with a voltage source and a current source. The problem involves applying Kirchhoff’s Voltage Law (KVL) and Kirchhoff’s Current Law (KCL) to determine individual voltage drops. Initial attempts incorrectly assumed current relationships, leading to inconsistent voltage values violating Kirchhoff’s laws. Correct analysis shows that the current through the first resistor (Rab) and the second resistor (Rbc) differ due to the presence of a 1A current source in parallel. Using the Norton equivalent circuit transformation (converting the voltage source and series resistor into a current source with parallel resistors) clarifies the problem. The final correct solution finds the current through Rab as 0.5A, resulting in a voltage drop of 0.5V, and the voltage drop across Rbc as 1.5V, satisfying both KCL and KVL. Ohm’s Law (V=IR) is fundamental in these calculations. The discussion highlights the importance of correctly modeling the circuit and carefully applying circuit laws to solve for voltage drops in complex circuits involving current sources.
TL;DR: For a 2 V source with two 1 Ω resistors and a 1 A current source between them, "Vab = 0.5 V; Vbc = 1.5 V." Solve using KCL (Ibc = Iab + 1) and KVL (2 = Vab + Vbc). [Elektroda, Steve Lawson, post #21670081]
Why it matters: This FAQ helps students and hobbyists quickly calculate individual voltage drops in mixed source series circuits without sign errors.
How do I find the voltage drop across each of the two 1 Ω resistors in this mixed-source loop?
Write KCL: Ibc = Iab + 1. Write KVL: 2 = Iab·1 + Ibc·1. Solving gives Iab = 0.5 A and Ibc = 1.5 A. Then Vab = 0.5 V and Vbc = 1.5 V. [Elektroda, Steve Lawson, post #21670081]
What equations should I write first (KCL/KVL) to avoid sign mistakes?
Use KCL at the middle node: Ibc = Iab + 1. Then apply KVL around the loop: 2 = Vab + Vbc = Iab·1 + Ibc·1. Solve for currents, then voltages. “KCL plus KVL nails it.” [Elektroda, Steve Lawson, post #21670081]
Why did someone get 1.5 V across both resistors, and why is that wrong?
That came from a sign error in KCL. If both drops were 1.5 V, KVL would give 3 V, contradicting the 2 V source. The KCL sum at the node would also fail to balance. [Elektroda, Steve Lawson, post #21670076]
What are the actual currents through each resistor here?
From KCL and KVL, Iab = 0.5 A through the left 1 Ω resistor, and Ibc = 1.5 A through the right 1 Ω resistor. That’s a 3× current difference due to the 1 A current source. [Elektroda, Steve Lawson, post #21670081]
How can Norton’s theorem simplify this problem?
Convert the series voltage source and its resistor to a Norton current source in parallel with a resistor. In that equivalent, the two resistors are in parallel and share the same node voltage, clarifying the 1.5 V on the right branch. [Elektroda, Sajed Rakhshani, post #21670080]
What is a Norton equivalent circuit?
It’s an equivalent representation of any linear two-terminal network as a current source in parallel with a resistor. Here, converting helps visualize parallel elements sharing the same voltage. [Elektroda, Sajed Rakhshani, post #21670083]
Can you give me a quick 3-step method to solve similar circuits?
  1. Write KCL at the critical node(s) to relate branch currents.
  2. Write KVL around the loop(s) to relate voltages and currents.
  3. Use Ohm’s law to compute individual drops and verify with KCL/KVL. [Elektroda, Steve Lawson, post #21670073]
How do I compute power in each resistor for this case?
Use the solved values: Vab = 0.5 V and Vbc = 1.5 V across 1 Ω each. Power is Pab ≈ 0.25 W and Pbc ≈ 2.25 W. Higher power on the right branch reflects the larger 1.5 A current. [Elektroda, Steve Lawson, post #21670081]
What common sign convention pitfall should I watch for?
Be consistent with current directions when writing KCL. Swapping the relation to Iab = Ibc + 1 leads to incorrect voltages and KVL failure. “Mind the arrows; math follows.” [Elektroda, Steve Lawson, post #21670076]
If the resistor values change, how do I adapt the solution?
Keep the same equations: KCL at the node and KVL around the loop. Replace 1 Ω with your actual Ra and Rb, solve currents, then use V = I·R to get each drop. [Elektroda, Steve Lawson, post #21670073]
How do I verify my hand calculation quickly?
After solving, check KVL (sum of drops equals the source) and KCL at the node. You can also run a quick simulation; the thread author validated results that way. [Elektroda, Sajed Rakhshani, post #21670080]
What is Ohm’s law and how is it used here?
Ohm’s law states V = I·R. After finding currents from KCL/KVL, multiply by each resistor value to get voltage drops across the resistors. [Elektroda, Cody Gass, post #21670085]
