How to Design a Circuit for Real Time Wireless Digital Square Wave Pulse Transmission?
225 10
How can I design a wireless transmitter and receiver that reproduce a continuous digital square-wave pulse at the far end in the same form for oscilloscope checking?
You need to define the data rate, whether the link is one-way or bi-directional, the wireless range, the voltage levels, and the supply voltage before you can choose a circuit; without those details, the design cannot be specified properly [#21670137] For this kind of RF link, timing is critical, so you need a CPU or microcontroller-based approach that handles bit timing, sampling, start/stop bits, clock recovery, and possibly Manchester encoding and CRC/error checking [#21670140] The reply also warns that instruction timing matters: if the pulse width is shorter than what the processor can reliably sample, the design will fail [#21670140] Since you want about 10 m of one-way wireless range and a 0–15 kHz square-wave input, an off-the-shelf UHF transceiver module may be a practical starting point rather than building the RF path from scratch [#21670144] A TI application paper on serial transceiver design is suggested as background reading, and a Micrel MICF620 UHF transceiver module is mentioned as a possible part to evaluate [#21670144]
  • Suggesting 420–800 MHz transceiver with CRC and pulse framing
    #1 21670136
    Mark Harrington
  • #2 21670137
    DAVID CUTHBERT
  • #3 21670138
    Ashwani Kumar
  • Request for circuit and code to relay square-wave pulses
    #4 21670139
    Ashwani Kumar
  • #5 21670135
    Ashwani Kumar
  • Data rate and instruction timing are critical
    #6 21670140
    Mark Harrington
  • #7 21670141
    Mark Harrington
  • #9 21670143
    Mark Harrington
  • #11 21670145
    Mark Harrington
The discussion focuses on designing a wireless circuit for real-time transmission of digital square wave pulses, with a specified frequency range of 0-15 kHz, one-way data flow, and a wireless range of up to 10 meters. The transmitter input is a square wave from an NPN transistor with a 2.7 kΩ pull-up resistor, powered by 8-25 V DC at a maximum current of 12 mA. Key design considerations include defining data rate, signaling path, voltage levels, and power supply. The importance of programming knowledge is emphasized for implementing pulse sampling, start/stop bit detection, clock synchronization, and error checking methods such as CRC or Hamming distance for parity verification. Suggested approaches include using microcontrollers for bit-banging and signal decoding. Off-the-shelf UHF transceiver modules like the Micrel MICF620 are recommended for wireless communication. Reference to Texas Instruments application notes provides additional guidance on RF transceiver design. The discussion highlights the complexity of RF digital pulse transmission and the necessity of understanding both hardware and software aspects for successful implementation.
