Microcontroller and Software for Timed Pulse Outputs Based on Pin Inputs and Delays
267 7
  • Microcontroller timing sequence with adjustable pulse delay
    #1 21670641
    Andrew Betts
  • #2 21670642
    Frank Bushnell
  • PICAXE and Arduino as easier alternatives
    #3 21670643
    Steve Lawson
  • PICAXE suited for hobbyist one-off designs
    #4 21670644
    Steve Lawson
  • Beginner PIC hardware and timing loop guidance
    #5 21670645
    Andrew Betts
  • #6 21670646
    Steve Lawson
  • Tutorials recommended for learning by experimentation
    #7 21670647
    Steve Lawson
  • PICAXE as beginner-friendly BASIC microcontroller platform
    #8 21670648
    Frank Bushnell
A novice electronics hobbyist seeks guidance on hardware and software to implement a timed pulse output system controlled by input pins and delays. The system requires monitoring input pins for start/stop signals and zero-crossing pulses, then generating timed output pulses on multiple pins with precise delays (0 ms, 5 ms, 8 ms, 9 ms) and durations suitable for driving opto-isolators. Respondents recommend beginner-friendly microcontroller platforms such as PICAXE and Arduino for ease of programming and learning. PICAXE is highlighted for its BASIC programming environment, flowchart-based programming, and sufficient I/O capabilities for hobby projects, with free software and affordable hardware components. Arduino offers a more sophisticated development environment with extensive community support. The discussion emphasizes starting with tutorials, experimenting with simple circuits, and gradually learning microcontroller programming concepts including timing loops and input pulse detection.
