Seamless Power Source Switching for EFI: Lithium Battery to Generator, No Back-Charge
360 10
How can I automatically switch an EFI system from a lithium battery to an engine generator without a drop-out, while preventing the generator from back-charging the battery?
Use diode OR-ing (steering diodes) if the generator voltage will always be at least about 1 V higher than the battery, and use Schottky diodes to keep the forward drop and power loss as low as possible [#21670890][#21670893] At your stated 2.5 A load, the example Schottky part discussed has about a 0.3 V forward drop at 125 °C and around 0.75 W dissipation, so a bench test is a good idea to confirm the EFI will tolerate the reduced supply voltage [#21670893] The tradeoff is reverse leakage; the cited diode was about 1 mA at high under-hood temperature, which may be acceptable if the battery is only connected during use [#21670893][#21670894] If the diode drop is not acceptable, the next step is an ideal-diode or hot-swap controller such as the Linear Technology LTC4359 [#21670895] For vehicle-style use, choose parts rated for automotive service, including spikes up to 60 V, 24 V jump-start conditions, and reversed battery connection [#21670897]
  • Automatic source switching without battery back-charge
    #1 21670889
    Casey Fordyce
  • Steering diode works if generator stays 1 V higher
    #2 21670890
    DAVID CUTHBERT
  • Request for hot swap circuit sources
    #3 21670891
    Casey Fordyce
  • Schottky diode choice and leakage tradeoff
    #5 21670893
    DAVID CUTHBERT
  • Suggesting active ideal-diode alternatives to diodes
    #6 21670894
    Casey Fordyce
  • #9 21670897
    DAVID CUTHBERT
  • #10 21670898
    Casey Fordyce
  • #11 21670899
    Saty Barole
The discussion addresses the design of an automatic, seamless power source switching system for a small engine EFI application, transitioning from a lithium battery pack used at startup to an on-engine generator once running. The goal is to prevent back-charging the battery from the generator and maintain battery availability if the generator fails. A simple diode ORing (steering diode) circuit can work if the generator voltage exceeds the battery voltage by at least 1V, but this introduces a diode forward voltage drop (~0.3V with Schottky diodes) and power dissipation. Schottky diodes such as the VISHAY V30100S-E3/4W are recommended for minimal voltage drop and power loss, with considerations for reverse leakage current. For more advanced solutions with lower losses, hot swap or ideal diode controllers are suggested. The Linear Technology LTC4359 Ideal Diode controller is cited as a suitable example for such applications. However, automotive-grade components must handle voltage spikes up to 60V, reversed battery conditions, and transient loads. Prototyping with MSOP-8 breakout boards is mentioned for testing. The system voltage is approximately 14.4V from a three-phase generator rectified by an ATV-type regulator, with battery voltages ranging from 12.6V (3-cell LiPo) to 14.8V (4-cell LiPo) and a maximum current draw of 2.5A.
