How to Automatically Switch 12V 6A Fan Between Power Supply and Battery Backup?
267 6
  • Diode-OR supply switching for 12V fan
    #1 21672271
    Piotr Marciszewski
  • #2 21672272
    John Schmitz
  • #3 21672273
    Piotr Marciszewski
  • 12 V lead-acid battery with smart charger backup
    #4 21672274
    John Schmitz
  • #5 21672275
    Piotr Marciszewski
  • #6 21672276
    John Schmitz
  • #7 21672277
    Blake Kopachena
The discussion addresses designing a circuit to power a 12V, 6A fan from a primary 12V power source with an automatic switch to a battery backup when the main power is disconnected. The user considers using two 9V batteries with resistors to achieve 12V but acknowledges the complexity of charging and regulating rechargeable batteries. A simpler solution proposed is using a 12V lead acid battery with a 10A smart charger/maintainer to allow continuous charging and prevent overcharging without manual switching. For automatic switching, a relay can be employed to disconnect the battery when the main power is present, though brief overlap of power sources during switching may occur. The main power source is intended to be a 12V motorcycle battery, and the backup battery should be compact, ideally a 9V rechargeable. The circuit must be portable and capable of managing charging and power source selection effectively.
