Circuit to Interface 1GB SD Card to P89V51RD2 via SPI and MAX232 for Hyperterminal
207 10
How can I connect a 1 GB SD card to a P89V51RD2 microcontroller over SPI and send data to HyperTerminal through a MAX232?
You need to connect the SD card to the P89V51RD2 through the SPI lines (MISO, MOSI, CLK, and CS), not directly to HyperTerminal, and use a proper microcontroller+SD-card interface schematic [#21671043][#21671048] The SD card should ideally be powered at 3.3 V; applying 5 V may work but will shorten the device life [#21671045] The card can run from 0 to 25 MHz, but the microcontroller must be programmed to read the SD card before it will work [#21671047] If HyperTerminal shows nothing, first short pins 2 and 3 of the RS232/D9 connector to verify the terminal and serial path are working [#21671047][#21671052] If HyperTerminal still misbehaves, try another terminal program because HyperTerminal has known problems and is not included on Vista/7 [#21671052]
  • #1 21671042
    Darpan Damani
  • #2 21671043
    Neil Mula
  • #3 21671044
    Darpan Damani
  • #4 21671045
    Neil Mula
  • #5 21671046
    Darpan Damani
  • Loopback test for HyperTerminal and SD card setup
    #6 21671047
    Neil Mula
  • #7 21671048
    Neil Mula
  • Missing SD card initialization and UART code
    #8 21671049
    Darpan Damani
  • #9 21671050
    Darpan Damani
  • #10 21671051
    Nikki Martinez
  • Recommend using other terminal programs than HyperTerminal
    #11 21671052
    Neil Mula
The discussion focuses on interfacing a 1GB SD card with the P89V51RD2 microcontroller using SPI communication and connecting it to a PC HyperTerminal via a MAX232 level converter. A simple schematic was shared to illustrate the connections. It was clarified that the SD card requires a 3.3V supply, and applying 5V can damage the card. The microcontroller firmware must be programmed (burned) to handle SPI communication with the SD card. The SD card can operate up to 25MHz SPI clock frequency. Troubleshooting steps include verifying HyperTerminal functionality by shorting RS232 pins 2 and 3, and trying alternative terminal programs like uVision 3 or Flash Magic due to known HyperTerminal issues on newer Windows versions. Sample SPI initialization code for the P89V51RD2 was provided, but the user reported no response on HyperTerminal, indicating possible issues with code or hardware connections. An ISP programmer or onboard burning facility is required to program the microcontroller. The discussion emphasizes correct wiring of MISO, MOSI, CLK, and CS lines between the microcontroller and SD card, proper voltage levels, and verifying terminal communication.
