Why Are Half-Bridge Capacitor Voltages Not Vs/2 in IR2153 LTspice Simulation?
423 9
Why are the two half-bridge capacitors in my IR2153 LTspice simulation not holding half the supply voltage, and what is causing the midpoint to shift?
The capacitor voltages are not staying at Vs/2 because the half-bridge midpoint only remains centered when both switches transfer identical charge over time; any mismatch in switch ON time or duty cycle makes the midpoint walk toward one rail. A tiny imbalance is enough to do it, so if one switch conducts slightly longer than the other, one capacitor slowly charges while the other discharges [#21671372] [#21671374] The poster was also advised that the IR2153 datasheet drives a series LC load against circuit common, while this schematic drives a capacitive divider, so the circuit should be tested in a simpler form first or driven against circuit common / a half-supply source [#21671378] One reply also noted the circuit is resonant at about 1.7 kHz with Q≈3, so the switcher should be operated at the intended resonant frequency and the circuit checked without the capacitive midpoint before troubleshooting further [#21671380]
  • Questioning why half-bridge capacitors are not Vs/2
    #1 21671371
    ak min
  • #2 21671372
    DAVID CUTHBERT
  • #3 21671373
    ak min
  • Duty-cycle mismatch shifts half-bridge capacitor midpoint
    #4 21671374
    DAVID CUTHBERT
  • #5 21671375
    ak min
  • #6 21671376
    DAVID CUTHBERT
  • #7 21671377
    ak min
  • #8 21671378
    DAVID CUTHBERT
  • Transformer loading shifts half-bridge capacitor voltages
    #9 21671379
    ak min
  • #10 21671380
    DAVID CUTHBERT
The discussion addresses why the voltages across the two capacitors in an IR2153-based half-bridge converter simulation in LTspice do not equal half the supply voltage (Vs/2) as theory predicts. The key issue is that for the midpoint voltage to remain stable at Vs/2, the charge transferred through each switch must be identical over time. Any imbalance in switch ON times causes one capacitor to charge while the other discharges, resulting in the midpoint voltage drifting toward one rail. This phenomenon is exacerbated by resonant effects and the presence of the transformer, which can alter the expected voltage distribution. Adjusting the switching frequency via the resistor on the Rt pin affects the capacitor voltages, and the circuit's resonant frequency and quality factor (Q) influence operation stability. Some designs include circuitry to compensate for ON-time differences to maintain the midpoint voltage. It is also suggested to test the circuit without the capacitive midpoint or transformer to isolate the cause. Driving the IR2153 against circuit common rather than the capacitive divider may also impact the voltage balance.
