Designing 40V 200mA LED Strings on 4 PCBs Using STCS1A and 40V/3A Power Supply
324 7
  • Use four STCS1A current sinks from a 40 V supply
    #1 21671818
    bensen john
  • 40 V LED board may stress STCS1A limits
    #2 21671819
    Mark Nelson
  • #3 21671820
    Frank Bushnell
  • Seeking higher-voltage driver to avoid 40V surges
    #4 21671821
    bensen john
  • #5 21671822
    bensen john
  • Recommend 45–48 V supply and different driver
    #6 21671823
    Mark Nelson
  • Use 0.56 Ω Rfb and CL520 current balancing
    #7 21671824
    Steve Lawson
  • Remove one LED and jumper the string
    #8 21671825
    Steve Lawson
The discussion focuses on designing a circuit to drive four LED PCBs, each requiring 40V and 200mA, using a 40V/3A constant voltage power supply and STCS1A LED driver chips controlled by a microcontroller via PWM. The LED boards contain approximately 120 LEDs arranged in series/parallel, with each LED rated at a minimum of 3.2V and 20mA. Concerns were raised about the high operating voltage being close to the STCS1A's maximum rating (45V absolute max), which may risk damage from voltage surges or spikes, especially in noisy environments. The LED arrangement in parallel strings is noted as problematic due to uneven current distribution and brightness variations. It is recommended to design for the maximum forward voltage per LED (e.g., 3.6V) rather than the minimum to ensure proper operation, potentially requiring a higher supply voltage (45-48V) and a different driver chip with a higher voltage rating. The 5V buck regulator for the microcontroller is considered overkill given the low current draw, but the high input voltage limits alternatives. Adjusting LED brightness via PWM control is the main goal, with suggestions to verify LED specifications, consider equalizing resistors, and ensure compatibility between PWM control voltage and microcontroller logic levels.
