Using Osram Optotronic Dimmable Power Supply 250mA 12-54V for 120 LED PCB?
237 10
Can I use a 250 mA constant-current Osram Optotronic LED driver with a 120-LED PCB that is designed for about 200 mA at 38.4–43 V?
You can use it only with caution: that Osram unit is a constant-current LED driver, so it will try to regulate current up to 250 mA, and the 12–54 V figure is its voltage compliance range, not a fixed output voltage [#21671679][#21671681][#21671682] The board’s 5-parallel LED clusters are the bigger problem, because parallel LEDs can current-hog and end up brighter, hotter, and possibly damaged if their forward voltages do not match closely [#21671677][#21671681] If you try it, start from minimum current and increase slowly while watching LED temperature and total current; one suggestion was to keep it around 180 mA rather than going to 250 mA [#21671679][#21671683] The safest fix would be balancing resistors or a redesigned series/parallel layout, but you said you cannot modify the PCB [#21671677][#21671683] So the practical answer from the thread is: it may work, but not as a guaranteed drop-in replacement and not at the full 250 mA setting [#21671679][#21671681]
  • Current mismatch and voltage headroom for LED PCB
    #1 21671676
    bensen john
  • Parallel LEDs need series resistors
    #2 21671677
    Mark Nelson
  • #3 21671678
    bensen john
  • Current-limited supply can drive LED board safely
    #4 21671679
    Mark Nelson
  • #5 21671680
    bensen john
  • Constant-current supply would overdrive the LED array
    #6 21671681
    Steve Lawson
  • Explains voltage range limits on LED drivers
    #7 21671682
    Steve Lawson
  • Add 10 ohm balancing resistors to each LED string
    #8 21671683
    Steve Lawson
  • #9 21671684
    Mark Nelson
  • #10 21671685
    Steve Lawson
  • Sort LEDs by forward voltage before grouping
    #11 21671686
    Steve Lawson
The discussion addresses the suitability of using an Osram Optotronic dimmable power supply rated at 250mA and 12-54V output voltage range to power a PCB with 120 LEDs arranged in a series-parallel configuration. The PCB consists of 12 series clusters, each cluster having 5 parallel LEDs, with the total LED current requirement calculated at approximately 200mA and voltage between 38.4V to 43V. The power supply is a constant current driver with an adjustable voltage range to accommodate the LED string voltage at the set current. It is confirmed that the 250mA rating is the maximum current output, and the voltage range covers the required LED voltage, making the power supply generally compatible. However, parallel LED connections without individual current-limiting resistors can cause uneven current distribution, leading to some LEDs drawing more current, overheating, and premature failure. Adding series resistors to each parallel LED is recommended to balance current, though the PCB cannot be modified in this case. Users are advised to gradually increase current when powering the board and monitor LED temperature to avoid damage. Running LEDs at or near maximum rated current shortens lifespan; operating at reduced current (e.g., 180mA) is preferable. The power supply will attempt to maintain the set current by adjusting voltage within its range; if the LED forward voltage sum is outside this range, the LEDs may be under- or over-driven. Testing and sorting LEDs by forward voltage can improve balance in parallel groups, but this is not feasible without PCB modification. Overall, the Osram Optotronic driver can be used with caution, monitoring current and temperature, but the existing LED arrangement poses reliability risks.
