Hi, i'm building a DIY air cooler using an automotive 12V, 8Amps blower, and a 12V, 1.5Amps submersible pump. I intend to use a DC motor controller to reduce blower air speed, ranging from 40%-100%, i'm aware that reduces the power going to the blower (btw, does a DC controller reduce voltage or amperage?). What kind of adapter should i use to make it compatible with a 230V mains? and what type of rechargeable battery should i use in case of outdoor usage that will last for some time? Thank you
Nura Dansumaila
Nura Dansumaila
