Automating 24hr Corrosion Dip Test: Motorized Lift for 1-3lb Stainless Parts, 5 Travel
273 9
How can I build a simple desktop fixture to lift 1–3 lb stainless parts about 4–5 inches in and out of water every hour for a 24-hour corrosion test?
Build a counterweighted lift driven by a geared motor so the motor only has to overcome friction and starting/stopping inertia, then use limit switches and a timer to alternate the part in and out of the bath every hour [#21673148] One suggested layout is two pulleys with a rope or chain: one end holds the DUT and the other holds a counterweight equal to the DUT, with switches at the top and bottom travel points to stop motion [#21673148] A geared-down motor or an auto window lift motor was suggested as a practical drive option for this kind of small desktop fixture [#21673149] If you use a magnetic reed switch, drive a relay and make sure the switch/relay ratings exceed the motor’s stall current [#21673149] Another alternative is a pneumatic linear actuator with electric valves, if you have compressed air available [#21673154]
  • Suggesting a 4–5 inch hourly lift mechanism
    #1 21673146
    Scott Brown
  • Milliohmeter needed to detect oxide buildup
    #2 21673147
    Malcolm Whinfield
  • Counterweight pulley lift with limit switches
    #3 21673148
    Steve Lawson
  • Reed switch should drive relay for motor current
    #4 21673149
    Steve Lawson
  • #5 21673150
    Scott Brown
  • #6 21673151
    Scott Brown
  • #8 21673153
    Steve Lawson
  • #9 21673154
    Richard Gabric
  • #10 21673155
    Scott Brown
The discussion addresses the design of an automated test fixture for a 24-hour corrosion dip test involving stainless steel parts weighing 1-3 lbs, requiring a 4-5 inch vertical travel. The test cycle involves submerging parts in water for one hour, then raising them out for one hour, repeated over 24 hours. Solutions focus on mechanical actuation methods suitable for precise, repetitive motion with low load. Proposed mechanisms include a motorized pulley system with a counterweight to balance the load, using geared-down motors or automotive window lift motors for controlled vertical movement. Position detection can be implemented with switches such as pushbuttons, pressure switches, magnetic reed switches paired with relays, or optical sensors to automate start/stop of the motor at travel limits. Alternative suggestions include programmable linear actuators, pneumatic actuators from companies like Festo requiring compressed air, and programmable toy robotics kits such as LEGO Mindstorms or Lynxmotion servo erector sets for prototyping. The importance of motor stall current ratings and switch/relay contact ratings is emphasized to ensure reliable operation. The original poster seeks a simple desktop solution with programmable extension and retraction cycles for continuous 24-hour operation.
