Seven Segment Display Not Showing Numbers in Water Level Detector Circuit—Wiring Issue?
237 8
  • #1 21673240
    Iskandar Baharudin
  • #2 21673241
    Enrico Koeck
  • #3 21673242
    Iskandar Baharudin
  • #4 21673243
    Enrico Koeck
  • #5 21673244
    Iskandar Baharudin
  • #6 21673245
    Enrico Koeck
  • #7 21673246
    Iskandar Baharudin
  • #8 21673247
    Enrico Koeck
  • #9 21673248
    vikasbly44
The discussion addresses an issue with a seven-segment display in a water level detector circuit where no numbers appear when pins 3 and 8 are connected to ground, but the display lights up when connected to VCC without showing digits. The likely cause is the use of a common anode display instead of a common cathode, affecting proper operation. Testing by grounding individual segment pins (L-1 to L-9) can verify correct display functionality. The inquiry about pin 5 on the seven-segment display clarifies that it corresponds to the decimal point (DP) and can be left unconnected or tied high/low depending on whether illumination of the decimal point is desired.
