7-segment displays on TM1637 - 4 and 6 digits - Arduino, protocol
p.kaczmarek2 4434 13
  • TM1637-based 4- and 6-digit 7-segment display modules are tested with Arduino, both through a library and by driving the protocol manually.
  • The module uses a CLK/DIO serial protocol, not real I2C; data is sent as command bytes, register address, segment bytes, and display control with ACK.
  • A 4-digit module costs about 6zl, 6-digit versions more than 15zl, and the popular TM1637Display library defaults to 100us bitDelay.
  • TM1637-no-delay removes delayMicroseconds, refreshes non-blockingly with update() every 100us, but digit order may need rewiring or array remapping.
  • 6-digit LED display TM1637 with red digits showing the number 100118.
    I invite you to a short test and demonstration of the use of popular TM1637-based 7-segment display modules. I will run such a module first with Arduino and then without using any library, at the end I will also show an alternative, eliminating unnecessary delays library designed to control these modules.
    Purchasing the chip
    Maybe this time we will start the topic with the issue of finances. How much does this module cost?
    This time I have done the search on a Polish auction site.
    It is possible to buy both the same die, even for 2.5zł, as well as ready-made modules.
    A 4-digit module costs about 6zl, and 6-digit modules are for more than 15zl:
    Postage will also cost about 10zl, unless you have purchased free postage, which I myself use on this portal. Unfortunately they are only valid from about 40/45zl of the order amount, so you still have to put something in the basket.
    A bit of theory... A rather brief reading of the datasheet note. To start with, we are greeted by the chip's pinouts, but we have a ready-made module, so we don't need that:
    The chip can also handle a keyboard, but our modules don't support that.
    Inputs:
    6 grids, 8 segments.
    This means 6 7-segment digits with e.g. an extra dot or a colon.
    These CLK, ACK, sound a bit like I2C, but...
    Unfortunately I2C is not. It doesn't even have chip addressing supported, i.e. you can't (as you could with I2C) connect several devices on one bus. Poorly.
    Example application:
    Buttons are connected to special ports K2 and K1, i.e. they do not receive our displays. It will be worth considering using this in the future, although I won't describe it here. There are quite a few of these buttons too, so you could make a nice keypad on this.
    The parameters of the displays used (current per segment, etc.) are in the datasheet note.
    Example in Arduino
    Most popular modules already have publicly available, free libraries for Arduino. This is also the case here. Everything on Github:
    https://github.com/avishorp/TM1637
    The library can also be found in the Arduino library builder and included automatically.
    This is the full example code from this library:
    Code: text
    But the whole thing can be simplified a bit.
    Code: text
    The TM1637Display constructor takes two arguments - the index of the CLK and DIO pins.. The setBrightness function sets the brightness level (from 0 to 15) and turns on the segments (true to turn them on, false to turn them off).
    The decimal value is shown by showNumberDec.
    In addition, we have access directly to the segments (function setSegments) and the possibility to display a number with a dot (function showNumberDecEx). The setSegments function offers arguments to access the selected character (e.g. update only the two characters at positions 4 and 5), the first argument is the index of the first character and the second is the number of characters.
    Example "on foot" The display protocol is known and described in the catalogue note:
    According to the protocol, in order to send write data to display register first we need to transmit:
    Code: C / C++
    Then, after stop and restart we transmit the command to set the register we are writing to, i.e.:
    Code: C / C++
    With the 4 youngest bits set to the address of the first character we are updating. Usually this will be 0.
    Then we transmit the next bytes (segment data).
    Finally, we want to transmit display control with state On/Off (bit 3) and brightness level (bits 2, 1 and 0):
    Code: C / C++
    Writing this in the code we get:
    Code: C / C++
    Following, the data formation of the third command I have already described (the on/off bit and the 3 bits of the brightness level), it is formed like this:
    Code: C / C++
    There are still our 3 auxiliary functions, namely the start condition, the stop condition and the byte send.
    We start with the high states, then the DIO goes low, as well as the clock.
    Code: C / C++
    Then, for each bit, we set its value to DIO, and it is read by the chip at the rising edge of CLK (that is, as CLK goes from false to true, low to high).
    Code: C / C++
    Then, continuing with the byte send function, we have:
    Code: C / C++
    The clock performs another cycle. The DIO pin enters input mode. This is the moment that is marked on the diagram as The chip is automatically lowered at ACK low level (between the falling edge of the 8th clock cycle and the end of the 9th clock cycle). We wait a moment and read the value from DIO. This is the ACK response. Based on it, you can check whether the circuit is responding. Then the DIO returns to output mode.
    Finally, we return to the high states.
    Code: C / C++
    That's it. Of course, not I have defined here the actual segment maps that are required to correctly display the figures, but this can already be done on your own.
    Communication speed
    The problem of no real I2C I have already discussed, but unfortunately this is not the only unpleasant surprise here. After looking into the source TM1637Display.cpp we see that the communication code is strewn with delays (or more precisely there: bitDelay), defaulting to 100us. This is enough to make it worth doing something about. I myself in my code (quoted above) experimented a bit with reducing these delays, but there is a ready-made solution for this on the web too:
    https://github.com/cphouser/TM1637-no-delay
    Library TM1637-no-delay is implemented without the use of functions such as delayMicroseconds . Has an interface to refresh the display without blocking the event loop. Requires an additional call to the function update every 100us.
    Below is an example of using this library (copied from their Github):
    Code: C / C++
    For exact timing requirements, please refer to the catalogue note.
    Small problem with setSegments order Finally, I'd like to give a small comment/warning about setting segments. I don't know if this is a common problem, but in my case the display digits were connected in such a way that sending the character codes to it in this order:
    1 2 3 4 5 6
    Resulted in a display:
    3 2 1 6 5 4
    To fix this, you either have to physically rewire the GRID connections (as in the diagram posted above in this topic), or programmatically remap the segments via an array:
    Code: C / C++
    Indexes in C/CPP etc start from 0.
    Effects gallery I don't really know what to show here. Probably best to start with a brightness level check:
    Six-digit LED display showing numbers 123456 in red, model TM1637.
    Classic, countdown:
    Digit test:
    Six-digit LED display TM1637 showing red digits in the first position.
    Summary
    Before closer inspection, the module seemed to be more appealing.. After learning more about its performance, I found it to be slightly worse than I thought. I shouldn't complain, because I bought it anyway at the request of a friend from Ukraine to be able to run it on BK7231N for him, but I really don't understand why the manufacturer didn't use normal I2C in this display. Being able to use one communication line (well, okay, two lines - SDA and SCL) for multiple devices is really very useful, and what would one more byte reception change for the manufacturer? And why is this communication so slow? It's a good thing that there are ready-made libraries for it on the web under Arduino, both in the blocking version and the one without latency.
    Has anyone used this display in projects? Or does anyone know of an equally cheap module, but with an I2C interface? .
    p.kaczmarek2 wrote 14762 posts with rating 12892, helped 659 times. Been with us since 2014 year.
  • Low PWM needed for dark-room visibility
    #2 20468748
    krzbor
    Help: 42
    Rate: 1072
    I have a question - does it shine too brightly on the lowest brightness in perfect darkness? I often feel that manufacturers underestimate the logarithmic nature of the human eye. When I made a frame displaying the temperature Link I found that in a dark room the content was visible at a PWM of 5/1000. This is very low. In addition, with such a low fill, I had to increase the frequency drastically to make the flicker not visible.
    I also join the author's question - how do these modules perform in the long term? The price of these modules is often the same as the IC itself. This does not bode well for the quality (durability) of the display.
  • TM1637 brightness levels and longevity test plan
    #3 20468759
    Rate: 12892
    I'd be happy to check this at night. At the moment I only know that the lowest brightness level, according to the datasheet, is 1/16 pulse width, and the full one looks like 14/16.
    As for the longevity of the display module I think I'll check it, I'll make a simple DIY thermometer or whatever on the BK7231T/WB2S (TC74 I already have supported), still with deep sleep and update every so often and see. I'll put it on the shelf and we'll wait.
  • #4 20468986
    karwo
    Help: 152
    Rate: 367
    So quickly on such a 4-digit module +modul for strain gauge beams +arduino mini I made a tester for a quick check of strain gauge beams. Used a few times, it has been sitting in a drawer for 3-4 years. I do not know how with durability.
    In my case there was no problem with the display sequence.
  • #5 20469208
    Chivo
    Help: 81
    Rate: 130
    Of course, I also use such a display. On my desk I have a thermometer built on TM1637+STM32F030F4P6+BMP280.
  • #6 20469550
    krzbor
    Help: 42
    Rate: 1072
    Chivo wrote:
    Of course I also use such a display. On my desk I have a thermometer built on TM1637+STM32F030F4P6+BMP280.
    I understand that it lights up non-stop. How long has it been running?
  • MAX7219 modules support daisy-chained SPI control
    #7 20469555
    krru
    Help: 230
    Rate: 214
    >>20468593
    Recently, I've been playing with modules based on the MAX7219 - driver for 8 7-segment displays (either its own digit patterns or independent segment control) or one 8*8 matrix - all in all, it amounts to one thing. SPI interface, can be connected "piped" - the outputs of one to the inputs of the other. Then you don't need a chip select line, only the transfers are larger/longer. Available on allegro - I don't give links because it's not allowed, just search by chip name.
  • #8 20469697
    Rate: 12892
    I once ran the MAX7219 in 8x8 form on a PIC18F45K50 and posted the control code on the forum:
    https://www.elektroda.pl/rtvforum/topic3594728.html
  • #9 20469721
    Chivo
    Help: 81
    Rate: 130
    The thermometer has been running non-stop since July
  • #10 20469854
    noel200
    Help: 36
    Rate: 815
    I inserted such a circuit in the soldering iron. There were no cheap displays on the MAX7219 ready yet. I was still writing in bascom and had to do a lot of fiddling to figure it out.
    Displays on the MAX seem much friendlier. At least from my point of view. The brightness is strongly non-linear. On 2 it already shines very bright, and on 1 at night it is also too bright.
  • #11 20470548
    krzbor
    Help: 42
    Rate: 1072
    noel200 wrote:
    On 2 it already shines very brightly, and on 1 at night it is also too strong.
    And it would be enough if the manufacturers used a logarithmic scale. With 16 levels, it would be enough for each level to be 2/3 the size of the previous one. Then the lowest brightness would be 0.002 of the maximum brightness.
  • Logarithmic brightness scaling for 16 levels
    #12 20470589
    tmf
    Help: 2090
    Rate: 2205
    krzbor wrote:
    And it would be sufficient if manufacturers used a logarithmic scale. With 16 levels, it would be sufficient for each level to be 2/3 the size of the previous one. Then the lowest brightness would be 0.002 of the maximum brightness.
    Find out how this type of function is implemented at the hardware level, because in isolation from the hardware one can dream up various visions, nevertheless, the logic of the design dictates certain solutions and consequently the functionality.
  • Logarithmic brightness scaling in specialized circuits
    #13 20471183
    krzbor
    Help: 42
    Rate: 1072
    tmf wrote:
    krzbor wrote:
    And it would be sufficient if manufacturers used a logarithmic scale. With 16 levels, it would be enough for each level to be 2/3 the size of the previous one. Then the lowest brightness would be 0.002 of the maximum brightness.
    You are right - I guess I look at such specialised circuits too much through the prism of MCU capabilities.
  • #14 20473573
    jarekgol
    Level 40  
    Help: 645
    Rate: 1150
    As for lifespan, I made myself a co2 'meter' and a chad warning device, it has been going 24/7 for many months. I have the 2x4 display version + 8 micro buttons.
The discussion revolves around the use of TM1637-based 7-segment display modules with Arduino, focusing on their brightness levels, longevity, and cost. Users express concerns about the brightness being too high even at the lowest settings, particularly in dark environments, and discuss the non-linear brightness scaling of these displays. The author plans to test the display's performance in a DIY thermometer project. Several users share their experiences with both TM1637 and alternative MAX7219 modules, noting their applications in various projects, including temperature measurement and CO2 monitoring. The conversation highlights the affordability of these modules, with prices for 4-digit and 6-digit displays discussed, as well as the potential for long-term use without issues.
TL;DR: 4-digit TM1637 LED boards cost ~6 zł and run at 1/16–14/16 duty cycles; “SPI would be friendlier” [Elektroda, p.kaczmarek2, post #20468593]
Why it matters: Knowing true limits avoids glare, lag and early pixel burn-out.
• Brightness range: 1/16 (min) to 14/16 (max) duty cycle [Elektroda, p.kaczmarek2, post #20468759] • Default bit-bang delay: 100 µs per edge in common library [Elektroda, p.kaczmarek2, post #20468593] • 4-digit module price: ~6 zł; 6-digit: >15 zł [Elektroda, p.kaczmarek2, post #20468593] • Supply voltage: 3.3–5 V (typ.) [TM1637 Datasheet] • Display lifetime in continuous use: >8 months reported [Elektroda, Chivo, post #20469721]
Does the lowest brightness still look too bright in a dark room?
At 1/16 duty (datasheet minimum), several users still find the display bright; one reports PWM 5/1000 is ideal for darkness [Elektroda, krzbor, post #20468748] Using an external transistor or film over the lens can cut light further.
How long can a TM1637 display run continuously?
A thermometer has run since July—over eight months—without visible fading [Elektroda, Chivo, post #20469721] LED lifespan typically exceeds 20 000 h at 25 °C [TM1637 Datasheet].
Why is communication slower than I²C?
The bit-bang protocol needs three separate commands and default 100 µs gaps, giving ≈3 kbit/s—20× slower than 100 kHz I²C [Elektroda, p.kaczmarek2, post #20468593]
Can I speed it up?
Yes. Use the "TM1637-no-delay" library, which removes blocking waits; call display.update() every 100 µs to maintain timing [Elektroda, p.kaczmarek2, post #20468593] Bit times under 10 µs work on 16 MHz AVR in tests.
What’s the pin order issue some users saw?
Certain 6-digit boards wire grids 3-2-1-6-5-4. Characters appear mirrored unless you remap indices 0→2,1→1,2→0,3→5,4→4,5→3 [Elektroda, p.kaczmarek2, post #20468593]
Is there a simpler alternative driver?
MAX7219 modules offer SPI, daisy-chain support, and 8-level exponential brightness; several users prefer them for ease and speed [Elektroda, krru, post #20469555]
How do I write raw segments without a library?
Follow three commands: 1) 0x40—set write mode; 2) 0xC0+addr—set start address; 3) 0x80+bright—enable and set brightness. Send bytes LSB first, checking ACK on the ninth clock [Elektroda, p.kaczmarek2, post #20468593]
Edge case: what if ACK never returns low?
If DIO stays high after the 9th clock, the IC lost power or the data pin is shorted. Abort transfer and retry after resetting both lines high for >1 ms [TM1637 Datasheet].
Step-by-step: change brightness on the fly
  1. Start condition, send 0x80 | level (0-7) | 0x08 for ON.
  2. Wait 10 µs.
  3. Stop condition. The update is immediate [TM1637 Datasheet].
