Can a clock pendulum be slowed by adding a resistor to the PSB?
390 10
Can I slow an AA-battery pendulum mechanism from 60 swings per minute to 30 or 20 by adding a resistor or changing the capacitor?
No—adding a resistor to the PSB, changing the capacitor, or lowering the battery voltage will not slow the pendulum; the swing rate is set by the pendulum’s length and mass, while the battery only supplies a small energy kick to keep it moving [#21674568][#21674569][#21674570] The only ways suggested to reduce the swing frequency are to increase the pendulum length or increase the weight at the end [#21674569] One reply also noted that changing the resistor or capacitor in the oscillator circuit can alter the drive frequency, but this would affect the electronics, not the pendulum’s natural swing rate, and may only change the swing arc [#21674564][#21674565]
  • Changing capacitor value to slow pendulum swing
    #1 21674561
    Now Clock
  • Clarifying battery power and pendulum synchronization
    #2 21674562
    Kevin Angelo Ma
  • Need alternative way to slow battery-driven pendulum
    #3 21674563
    Now Clock
  • Adjust the RC network to halve the oscillator frequency
    #4 21674564
    Sambath Kumar
  • #5 21674565
    Justin Spencer Mamaradlo
  • Oscillator frequency controls pendulum speed, not battery voltage
    #6 21674566
    Sambath Kumar
  • #7 21674567
    Now Clock
  • Battery only supplies synchronized energy kicks
    #8 21674568
    richard gabric
  • Pendulum frequency set by length and weight
    #9 21674569
    Frank Bushnell
  • Pendulum frequency set by length, not drive energy
    #10 21674570
    richard gabric
  • #11 21674571
    Now Clock
The discussion addresses the feasibility of slowing the swing frequency of battery-powered wall clock pendulums, originally designed to swing about 60 times per minute, down to 30 or 20 swings per minute. The pendulum mechanisms are driven by an oscillator circuit on a PCB, powered by a standard AA battery, without traditional mechanical gears. The natural frequency of a pendulum is primarily determined by its length and weight, which cannot be altered further in this case. Attempts to modify the swing rate by adding resistors or changing capacitor values in the oscillator circuit were suggested, as the oscillator frequency controls the electromagnetic impulses sustaining the pendulum motion. However, multiple contributors clarified that the pendulum's swing frequency is governed by physical pendulum properties and cannot be effectively slowed by electrical component changes alone. Lowering battery voltage is ineffective as it would stop the mechanism. The battery and oscillator only provide energy to maintain the natural swing against damping forces, not to alter its frequency. The consensus is that without changing pendulum length or mass, or redesigning the mechanism, slowing the swing rate is not achievable by simple resistor or capacitor modifications on the PCB.
