Adding A2DP Bluetooth Receiver to Nokia CK-200 Car Kit for Wireless Music Streaming
372 8
  • Using a separate A2DP receiver with the CK-200 harness
    #1 21674778
    Mikayil Abdullayev
  • #3 21674780
    Mikayil Abdullayev
  • #4 21674781
    Kevin Angelo Ma
  • Becker 3100 outputs stereo for car kit
    #5 21674782
    Mikayil Abdullayev
  • #6 21674783
    Kevin Angelo Ma
  • Nulaxy KM24 as Bluetooth music workaround
    #7 21674784
    Gosha Cruel
  • #8 21674785
    sham 10
  • #9 21674786
    CLAIRE DIVAS
The discussion centers on integrating A2DP Bluetooth audio streaming capability into a Nokia CK-200 car kit, which originally supports only mono Bluetooth calls without stereo output or A2DP profile. The user has successfully connected the CK-200 to a Becker 3100 head unit via the tape deck input, which supports stereo and Dolby sound but lacks AUX input. Attempts to modify the CK-200 for stereo output and A2DP support were unsuccessful. Suggestions include adding an AUX input to the head unit to facilitate external Bluetooth receivers. One alternative solution mentioned is replacing the existing setup with a dedicated Bluetooth hands-free car kit like the Nulaxy KM24, which supports A2DP streaming, automatic pairing, and good audio quality. Key technical challenges involve wiring the Bluetooth receiver to the car speakers, powering it with ignition-switched supply, and integrating mute control signals to prioritize calls over music streaming.
