Adding Bluetooth Audio Receiver to 1940s Tube Radio Using SW/MW Switch for Input
444 23
Can I add a Bluetooth audio receiver to a 1940s tube radio, and where should I inject the audio signal?
Yes, it can be done, but you need the radio schematic and should inject the Bluetooth audio into the audio preamp stage rather than directly into the RF/IF stages [#21666073][#21666081] A Bluetooth A2DP audio module is suitable, and one reply notes these modules typically need about a 4–5 V supply [#21666074] If you use the SW/MW switch as an input selector, make sure the Bluetooth feed is AC-coupled through a capacitor, with about 10 µF at 50 V mentioned, and use screened leads to reduce hum [#21666082] Because the set is old and may have chassis voltage issues, check chassis potential with a DVM before connecting anything and keep the Bluetooth power supply isolated [#21666086][#21666087] The install should ideally be reversible, and you may need some tinkering to get acceptable sound quality because vintage radios do not have flat audio response [#21666075][#21666081]
  • Clarifying Bluetooth input injection into tube amp
    #1 21666072
    Callum Cattle
  • Need schematic and preamp tube for Bluetooth input
    #2 21666073
    Earl Albin
  • Bluetooth Class 2 audio module recommendation
    #3 21666074
    Mark Harrington
  • Reversible professional installation recommended for vintage radio
    #4 21666075
    Earl Albin
  • Bluetooth modules now offer high-fidelity audio
    #5 21666076
    Mark Harrington
  • Advocates adding Bluetooth to preserve radio use
    #6 21666077
    Mark Harrington
  • #7 21666078
    Callum Cattle
  • #8 21666079
    Mark Harrington
  • #9 21666080
    Callum Cattle
  • Bluetooth audio input is possible but needs tinkering
    #10 21666081
    Earl Albin
  • Add input switch, shielding, and 10 µF coupling capacitor
    #11 21666082
    Mark Harrington
  • Using a radio as a low-power transmitter
    #12 21666083
    Earl Albin
  • MP3 quality and 60 Hz hum criticized
    #13 21666084
    Earl Albin
  • #14 21666085
    Callum Cattle
  • Check chassis potential before connecting Bluetooth circuit
    #15 21666086
    Mark Harrington
  • Cap-couple the audio and verify chassis potential
    #16 21666087
    Earl Albin
  • #17 21666088
    Earl Albin
  • #18 21666089
    Callum Cattle
  • Recommend the highest-power Bluetooth module with antenna
    #19 21666090
    Earl Albin
  • Kc6112 recommended for Bluetooth audio streaming
    #20 21666091
    Mark Harrington
  • #21 21666092
    Mark Harrington
  • Bluetooth audio limitations and antenna importance argued
    #22 21666093
    Earl Albin
  • Bluetooth audio as a practical modern retrofit
    #23 21666094
    Mark Harrington
  • #24 21666095
    Mark Harrington
Integrating a Bluetooth audio receiver into a 1940s tube radio using the SW/MW switch as an input selector is feasible but requires careful consideration of the radio's vintage circuitry and safety. The first step is obtaining the radio's schematic and identifying the audio pre-amplifier tube stage for proper audio input connection. A Bluetooth Class 2 A2DP module with audio capability, such as the KC6112, is recommended for its stereo streaming profiles and suitable power output. The Bluetooth module should be powered by a regulated 4.5V supply and isolated from the radio chassis to prevent electrical hazards, using AC coupling capacitors (e.g., 10µF rated at 50V) to decouple the audio input and avoid mains hum interference. A switch to select between the original radio input and the Bluetooth input is advised for flexibility. Users should expect limited audio fidelity due to the radio's non-flat frequency response and inherent limitations of Bluetooth audio compression (SBC, MP3, AAC, APT-X). Professional restoration and reversible installation are recommended to preserve the collectible value. Additional precautions include verifying chassis potential relative to earth ground with a digital voltmeter to avoid shock hazards. The discussion also highlights the trade-off between modern convenience and audio quality, noting that Bluetooth audio is widely adopted by major brands like Sony, Pioneer, and JVC despite some fidelity compromises.
TL;DR: Use a Class 2 Bluetooth audio module (range typically exceeds 20 m) and inject at the radio’s pre‑amp; “what you need is a Bluetooth Class 2 module with Audio capability.” [Elektroda, Mark Harrington, post #21666074]
Why it matters:** This FAQ helps hobbyists add Bluetooth to 1940s tube radios safely while preserving reversibility and sound quality.
Can I add Bluetooth to a 1940s tube radio without ruining it?
Yes. Treat the radio as a collectible and make changes reversible. Add Bluetooth as an auxiliary input and avoid cutting original parts. An expert advised professional, reversible installation for vintage sets to protect value and safety. [Elektroda, Earl Albin, post #21666075]
Where do I inject the Bluetooth audio signal?
Identify the audio pre‑amp tube stage from the schematic and feed the Bluetooth line‑level there. Old sets often include a pasted schematic; otherwise, find one online and list the tubes to locate the pre‑amp. This avoids disturbing RF sections. [Elektroda, Earl Albin, post #21666073]
Which Bluetooth audio module is recommended for this project?
Builders in the thread favored the KC Wirefree KC6112 as “the best of the lot” for A2DP/AVRCP use. It offers suitable profiles and integrates well when powered correctly and shielded. Choose modules that match these capabilities. [Elektroda, Mark Harrington, post #21666091]
What supply voltage does the module need?
Use approx. 4.5–5 V DC as specified for the recommended CSR BlueCore5‑based boards. Provide a clean, well‑decoupled supply to prevent noise. Avoid taking power from unisolated points inside hot‑chassis sets. [Elektroda, Mark Harrington, post #21666074]
How do I use the SW/MW band switch as an input selector?
Wire the switch to select radio front end or the Bluetooth input. Add shielding and a DC‑blocking coupling capacitor on the Bluetooth line to minimize hum when switching. Label positions clearly for safe operation. [Elektroda, Mark Harrington, post #21666082]
Is Bluetooth audio quality good enough on a tube radio?
Expect limits. Vintage radios lack flat 20 Hz–20 kHz response, and lossy codecs can reduce fidelity. As one expert put it, “these old radio/audio devices don’t have a flat 20HZ to 20KHz frequency response.” Use it for convenience, not hi‑fi benchmarks. [Elektroda, Earl Albin, post #21666081]
What range should I expect from a Class 2 Bluetooth receiver?
Typical Class 2 implementations on the cited module exceed 20 m under favorable conditions. Enclosures, placement, and antennas affect real‑world reach. Maintain clear line‑of‑sight when possible to reduce dropouts. [Elektroda, Mark Harrington, post #21666074]
How do I reduce 60 Hz hum and noise after adding Bluetooth?
Shield the Bluetooth board and leads, use a proper ground reference, and insert a 10 µF, 50 V coupling capacitor at the input. Keep audio wiring short and away from mains paths to reject hum in older sets. [Elektroda, Mark Harrington, post #21666082]
What safety checks must I perform before first power‑up?
Measure chassis to Bluetooth ground potential with a DVM set to at least 250 V. Confirm isolation and absence of half‑mains conditions before connecting. Skipping this can cause shocks or a destructive arc. [Elektroda, Mark Harrington, post #21666086]
Do I really need the schematic and tube list?
Yes. Start with the schematic to locate the audio pre‑amp and volume control. Document the tube lineup to confirm stages. This prevents damage to irreplaceable parts and guides a clean, reversible input path. [Elektroda, Earl Albin, post #21666073]
Quick 3‑step: how do I add Bluetooth input cleanly?
  1. Mount the Bluetooth board and shield its enclosure and leads.
  2. Add a switch to choose radio or external input via the band switch path.
  3. Insert a 10 µF, 50 V coupling capacitor to the pre‑amp input, then test. [Elektroda, Mark Harrington, post #21666082]
What are A2DP and AVRCP in plain English?
A2DP is the profile that streams stereo audio with codecs like SBC, MP3, AAC, and aptX. AVRCP enables play/pause and track controls between your phone and the module. The suggested module supports both profiles. [Elektroda, Mark Harrington, post #21666074]
Any edge cases I should know before streaming?
Hot‑chassis or leaky capacitors can place the radio at hazardous potential. A miswired ground can produce a loud bang, sparks, or injury. Verify isolation and voltages first to avoid failure on power‑up. [Elektroda, Mark Harrington, post #21666086]
Can the band‑switch mod be undone later?
Yes. Use existing switch poles and add wiring that you can remove without drilling the cabinet. Experts recommend reversible work to preserve collector value and future restoration options. [Elektroda, Earl Albin, post #21666075]
Where can I source the modules mentioned?
The thread cites KC Wirefree as a helpful supplier for A2DP/AVRCP modules. Contact the vendor for the KC6112 or similar boards and firmware support before you buy. [Elektroda, Mark Harrington, post #21666086]
My set label says 230 V, 60 W—anything special to note?
That rating reflects the OP’s radio. If you’re in a 120 V region, you’ll need appropriate step‑up transformation and safe isolation. Confirm mains configuration before powering any added electronics. [Elektroda, Callum Cattle, post #21666072]
