How to Create a Charge Separation to Migrate Ions in Solution
309 6
  • #1 21674992
    Lucas Watson
  • High-voltage transformer and Cockcroft-Walton suggestion
    #2 21674993
    richard gabric
  • #4 21674995
    richard gabric
  • #5 21674996
    Lucas Watson
  • Safety advice for high-voltage ion migration setup
    #6 21674997
    richard gabric
  • #7 21674998
    Lucas Watson
The discussion addresses the challenge of separating positively charged ions bound to negative counterions in solution using static electricity. A suggested approach involves applying a high voltage DC supply to create charge separation and ion migration. A high voltage transformer combined with high voltage rectifiers, possibly driven by a variac for adjustable output, can provide voltages in the 5-10 kV range. For higher voltages, a Cockroft-Walton generator can be used. The conductivity and impedance of the solution affect current and voltage stability; high impedance requires less current and simpler regulation, while low resistance may cause voltage maintenance issues. Safety considerations include insulating the beaker (preferably Pyrex or plastic) from metal supports, grounding all external metal parts, using well-insulated leads, and possibly incorporating series resistors to limit current to a few milliamps. Enclosures made of perspex and safety interlocks are recommended to prevent accidental contact and ensure safe operation. Voltages above 50 VDC should be treated as hazardous. The setup aims to establish proof of concept without necessarily requiring a regulated power supply.
